RTEMS time overflow problem
Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Mon Jun 29 14:35:22 UTC 2009
Hi,
which priorities did you take?
Please note: in general, rate monotonic works like a charm, so it would
help to give more information, otherwise we will not be able to help you.
And which tick period did you select?
Any other tasks running?
wkr,
Thomas.
Nasim Zehra wrote:
> thomas
>    yes i did .The mode of the tasks are preemptable and also i know that priorities  does not change in rate monotonic and i applied different priority to different task according to their execution time which was the criteria of rate monotonic.
> regards
> nasim zahra
> ________________________________________
> From: Thomas Dörfler [Thomas.Doerfler at embedded-brains.de]
> Sent: Monday, June 29, 2009 6:32 PM
> To: Nasim Zehra
> Cc: rtems-users at rtems.org
> Subject: Re: RTEMS time overflow problem
> Masim,
> unfortunately you did not mention how you created the tasks. did you
> apply the scheduling priorities properly (Note: The rate monotonic
> manager does NOT change task priorities. In just makes the tasks "ready"
> at the proper time.).
> Did you make the tasks preemptable?
> wkr,
> Thomas.
> Nasim Zehra wrote:
>> dear users
>>    also tell me that if i select periods of tasks such that when they are executed ,they are in running condition and before they are deleted ,time over flow error is occurred.Is there any solution for that.
>> i am having four tasks
>> 1st--------executed in 2202 ticks
>> 2nd-------// //            848
>> 3rd-----------------------246
>> 4th--------------------88
>>  above mentioned ticks are equal to execution time of respective tasks.
>> now i am selecting periods for them randomly so that upper bound condition for 4 tasks should be met according to rule of rate monotonic schedualing.like that
>>  1st---------8000 period in terms of ticks
>> 2nd---------3000
>> 3rd---------2000
>> 4th---------5000
>> using these periods my U = 69.85%
>> while theoritical U= 4(2(1/4) - 1)= 75.682%
>>  so 69 %<75%
>> => tasks are scheduable.
>> but implementing it causes ime oveflow error on T simulator for leon3 processor.
>> kindly help out.
>> regards
>> nasim
>> rtems-users mailing list
>> http://www.rtems.org/mailman/listinfo/rtems-users
> Embedded Brains GmbH
> Thomas Doerfler        Obere Lagerstrasse 30
> D-82178 Puchheim       Germany
> email: Thomas.Doerfler at embedded-brains.de
> Phone: +49-89-18908079-2
> Fax:   +49-89-18908079-9
