Scripts for building tools on Mac OS X
Alan Cudmore
Alan.P.Cudmore at nasa.gov
Thu Jun 11 21:03:12 UTC 2009
I'm still refining this script, but it I have it working on OS X,
Linux, and Cygwin so far.
You have to carefully edit the top part of the script to set the
correct versions of the tools and the patch names.
But once everything is set, it will download the tools and patches,
then it will patch, build and install the toolchain.
Make sure you have the wget binary available. For OS X, I got mine
from the macports project.
If it gets to a certain part of the script and dies, you can pick back
up by editing this part:
# Select what to build here. If the build stops on GCC, then there is
# no need to rebuild/install binutils.
DOWNLOAD_RTEMS_PATCHES=1
DOWNLOAD_BINUTILS=1
PATCH_BINUTILS=1
BUILD_BINUTILS=1
DOWNLOAD_GCC=1
PATCH_GCC=1
BUILD_GCC=1
DOWNLOAD_GDB=1
PATCH_GDB=1
BUILD_GDB=1
Just set the items that completed to 0 and it will skip them.
Alan
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20090611/75358783/attachment-0001.obj>
On Jun 11, 2009, at 4:40 PM, Groups (RTEMS, HC12) wrote:
> Hello all,
> We go sick and tired of being sick and tired and bought a bunch of
> Macs (perfectly good UNIX boxen).
> I am in need of scripts to build the tools and compilers for m68k
> hosted on a Mac.
> I could run the whole thing on a virtual XP box, but I'd rather eat
> worms^H^H^H^H^H^H^H^H^H just have it work.
> Thanks
> Andrei
> Andrei Chichak
> Systems Developer
> CBF Systems Inc.
> 4-038 NINT Innovation Centre
> 11421 Saskatchewan Drive
> Edmonton, Alberta
> T6G 2M9
> Phone: 780-628-2072
> Skype: andrei.chichak
> rtems-users mailing list
> rtems-users at rtems.org
