RTEMS use of Linux specific errno's
Chris Johns
chrisj at rtems.org
Thu Jun 11 22:38:27 UTC 2009
Joel Sherrill wrote:
> Hi,
> newlib cvs has moved EBADRQC and which
> is used by various files in /cpukit/libblock/src
> and some libchip drivers and ENOTBLOCK which is
> used by the fatfs to inside an ifdef which
> indicates it Linux specific. I
> only see two alternatives:
> + change the errno returned (probably best since
> it would be POSIX-ically correct and easier)
> + patch newlib to make these Linux-isms available.
> I am pretty happy changing EBADRQC to EINVAL but
> I don't know what ENOTBLOCK should change to.
> Attached is a patch which shows where these are.
> Thoughts?
I have no problem with any of the changes so please commit. I think
Peter's comments are also valid but I have no specific view either way.
Regards
