adding driver to bsp
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Jun 12 13:53:47 UTC 2009
lee wrote:
> Hi.
> Im trying to add a vmeUniverse driver to pc386 bsp. But im rather new to
> rtems.
> I've added the appropriate commands to the Makefile.am as instructed on
> the wiki. But now im getting these type of errors:
> /opt/rtems/c/src/lib/libbsp/i386/pc386/pci/pci.c:27:23: error:
> libcpu/io.h: No such file or directory
> /opt/rtems/c/src/lib/libbsp/i386/pc386/pci/pci.c:31:21: error:
> bsp/pci.h: No such file or directory
> /opt/rtems/c/src/lib/libbsp/i386/pc386/pci/pci.c:32:23: error:
> bsp/gtreg.h: No such file or directory
> /opt/rtems/c/src/lib/libbsp/i386/pc386/pci/pci.c:33:27: error:
> bsp/gtpcireg.h: No such file or directory
> I see that the "bsp dir" is set at configuration time? What is bsp dir?
Assuming you got the Makefile.am changes right...
+ are you using the RTEMS autotools ?
+ did you run bootstrap -p to regenerate the preinstall.am?
-joel
> Thanks for the help
> Kind Regards
> L
> rtems-users mailing list
> rtems-users at rtems.org
