about header files used in score
Chris Johns
chrisj at rtems.org
Sun Jun 14 23:10:59 UTC 2009
Zhongjie wrote:
> thanks for reply.
> I am just beginning studying RTEMS, the newlib depends on a limited
> number of low level functions.
Welcome.
> In fact, we do not need any C library to build gcc as a cross complier,
> like arm-elf-gcc, only enable the c
> language. what I concerns is that some part of RTEMS should can be
> compiled using those compiler.
If you look in libgcc2.c you will see an include for stdio.h. I have always
needed some libc headers to build gcc.
> Of course, with newlib support, RTEMS works well, it just a little
> confused logically for a beginner like me.
> as my understanding, it is a c library depends on a os, not a os depends
> a c library.
> I think we could define those types in rtems, then included by gcc and
> newlib, but not use those types directly in
> a c library header files. it will make the architecture more clearly.
GCC and newlib have all the types defined for a specific target and RTEMS uses
them.
Regards
