about header files used in score
Zhongjie zhurabbit at gmail.com
Tue Jun 16 03:02:53 UTC 2009
In systems like BSD, all functions needed in kernel space must be
implemented by their own.
I am not familiar with real time operation system such as RTEMS which
all are running in the
same address space, so I am a little confused about using C library.
Thanks for your reply.
Regards
Zhongjie
-----Original Message-----
To: Zhongjie <zhurabbit at gmail.com>
Cc: Chris Johns <chrisj at rtems.org>, rtems-users at rtems.org
<rtems-users at rtems.org>
Subject: Re: about header files used in score
Date: Mon, 15 Jun 2009 10:40:29 -0500
Zhongjie wrote:
> while, I think I got what you mean.
> I think we just need to make sure the "OS proper" and BSP code do not use
> some functions from C library. It is a little hard to tell which could
> be used and which could not be used, I think.
> One needs to know the detail implementation of the function in  the
> library
Not as much as you think.  Avoid IO.  You likely won't even be
tempted to use anything else that could be troublesome.
> Is there a list about which method could be used in BSP code?
In general, string and memory methods are OK.  malloc is owned by
RTEMS and is OK after the call to libc init from bootcard.
--joel
> Regards
> Zhongjie
> On Mon, Jun 15, 2009 at 9:51 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>     Zhongjie wrote:
>         When you build gcc, you could tell gcc whether you have a c
>         library, when you tell gcc you do not have
>         a c library, gcc will define "inhibit_libc", the stdio.h
>         included by libgcc2.c is in the section with "inhibit_libc"
>         defined, when you build gcc to *-elf- or *-eabi- , such
>         arm-elf-gcc or arm-eabi-gcc, you do not need any
>         c header files for the target.
>     While this is true for gcc in general, when you build an rtems
>     toolset,
>     you always build the C library at the same time.  This means gcc does
>     have access to newlib.
>     RTEMS "OS proper" code shouldn't be depending on the C Library
>     much except for base C99 types and methods like the memory
>     and string code which doesn't require OS support.
>     It doesn't impact the design of the OS.  It is just a set of features
>     that are maintained by someone else and always there.
>     --joel
>         Regards
>         Zhongjie
>         *From*: Chris Johns <chrisj at rtems.org
>         <mailto:chrisj at rtems.org>
>         <mailto:Chris%20Johns%20%3cchrisj at rtems.org
>         <mailto:Chris%2520Johns%2520%253cchrisj at rtems.org>%3e>>
>         *To*: Zhongjie <zhurabbit at gmail.com
>         <mailto:zhurabbit at gmail.com>
>         <mailto:Zhongjie%20%3czhurabbit at gmail.com
>         <mailto:Zhongjie%2520%253czhurabbit at gmail.com>%3e>>
>         *Cc*: rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>         <mailto:rtems-users at rtems.org <mailto:rtems-users at rtems.org>>
>         *Subject*: Re: about header files used in score
>         *Date*: Mon, 15 Jun 2009 09:10:59 +1000
>         Zhongjie wrote:
>         > thanks for reply.
>         > I am just beginning studying RTEMS, the newlib depends on a
>         limited > number of low level functions.
>         Welcome.
>         > In fact, we do not need any C library to build gcc as a
>         cross complier, > like arm-elf-gcc, only enable the c
>         > language. what I concerns is that some part of RTEMS should
>         can be > compiled using those compiler.
>         If you look in libgcc2.c you will see an include for stdio.h.
>         I have always needed some libc headers to build gcc.
>         > Of course, with newlib support, RTEMS works well, it just a
>         little > confused logically for a beginner like me.
>         > as my understanding, it is a c library depends on a os, not
>         a os depends > a c library.
>         > I think we could define those types in rtems, then included
>         by gcc and > newlib, but not use those types directly in
>         > a c library header files. it will make the architecture more
>         clearly.
>         GCC and newlib have all the types defined for a specific
>         target and RTEMS uses them.
>         Regards
>         Chris
>     Joel Sherrill, Ph.D.             Director of Research & Development
>     joel.sherrill at OARcorp.com        On-Line Applications Research
>     Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>      Support Available             (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20090616/41850ede/attachment-0001.html>
