Debian-host build error...
Ed Sutter esutter at alcatel-lucent.com
Tue Jun 30 14:29:20 UTC 2009
Ralf Corsepius wrote:
> Ed Sutter wrote:
>> Ian/Doran/Santosh,
>> Well, the story continues...
>> I managed to update my machine from etch to lenny (debain releases),
>> and that allowed me to successfully execute the tools (almost)...
>> Now the command "bfin-rtems4.10-gcc --help" actually prints the help
>> message, I don't see the message...
>>      bfin-rtems4.10-gcc: /lib/tls/i686/cmov/libc.so.6:
>>      version `GLIBC_2.4' not found (required by bfin-rtems4.10-gcc)
>> any more.
>> So, with that, I took a blazing step forward and actually tried to
>> compile a file with "bfin-rtems4.10-gcc main.c", and now I get this...
>>    /opt/rtems-4.10/libexec/gcc/bfin-rtems4.10/4.4.0/cc1:
>> /lib/i686/cmov/libc.so.6:
>>    version `GLIBC_2.8' not found (required by
>>    s4.10/4.4.0/cc1)
>> Somebody shoot me...
> It's quite simple: You are facing another incarnation of the same issue
> again. The rpms you are unpackaging and trying to use on Debian are
> incompatible to those libraries you have installed on Debian.
Yep, I realize that, I was just posting to the list for reference in case
someone else goes this route.  Note, I'm not complaining about the tools,
just trying to share the info.
> Unfortunately, you are still providing too little details, to be able to
> help.
> * Which glibc compatiblity modes does it supply?
> Run:
> nm -sD /lib/libc.so.6 | grep GLIBC
els:nm -sD /lib/libc.so.6 | grep GLIBC
00000000 A GLIBC_2.0
00000000 A GLIBC_2.1
00000000 A GLIBC_2.1.1
00000000 A GLIBC_2.1.2
00000000 A GLIBC_2.1.3
00000000 A GLIBC_2.2
00000000 A GLIBC_2.2.1
00000000 A GLIBC_2.2.2
00000000 A GLIBC_2.2.3
00000000 A GLIBC_2.2.4
00000000 A GLIBC_2.2.6
00000000 A GLIBC_2.3
00000000 A GLIBC_2.3.2
00000000 A GLIBC_2.3.3
00000000 A GLIBC_2.3.4
00000000 A GLIBC_2.4
00000000 A GLIBC_2.5
00000000 A GLIBC_2.6
00000000 A GLIBC_2.7
00000000 A GLIBC_PRIVATE
> * Which distro's rpms are you trying to use?
I'm running with Debian (lenny/stable).
Following is the list of rpms I ran through alien and installed...
rtems-4.10-autoconf-2.63-2.fc10.noarch.rpm
rtems-4.10-automake-1.11-1.fc10.noarch.rpm
rtems-4.10-bfin-rtems4.10-binutils-2.19.1-1.fc10.i386.rpm
rtems-4.10-bfin-rtems4.10-cpukit-4.9.99.0.20090206.2-1.fc10.noarch.rpm
rtems-4.10-bfin-rtems4.10-gcc-4.4.0-6.fc10.i386.rpm
rtems-4.10-bfin-rtems4.10-gcc-c++-4.4.0-6.fc10.i386.rpm
rtems-4.10-bfin-rtems4.10-gdb-6.5-6.fc10.i386.rpm
rtems-4.10-bfin-rtems4.10-newlib-1.17.0-39.fc10.i386.rpm
rtems-4.10-binutils-common-2.19.1-1.fc10.i386.rpm
rtems-4.10-gcc-common-4.4.0-6.fc10.i386.rpm
rtems-4.10-gdb-common-6.8.50.20090329-2.fc10.i386.rpm
rtems-4.10-newlib-common-1.17.0-39.fc10.i386.rpm
I guess my next step, as suggested by Daron, is to build the
tools on my machine.  Rumor has it that the "testing" version of
Debian supports GLIBC_2.8, but I don't wanna do that.
Thanks,
Ed
