Anyone booting RTEMS from MS-DOS?
Angelo Fraietta newsgroups at smartcontroller.com.au
Mon Mar 2 22:09:56 UTC 2009
You have to use a version of MSDos of 6.2. I am actually using Dr
Caldera Dos and it worked for me
Steven Grunza wrote:
> I'm trying to run the "Hello, world" application using the pc386 BSP.  I
> have a single board computer with built-in Flash.  The board currently
> boots into MS-DOS.  I tried following the information in
> http://www.rtems.com/wiki/index.php/Pc386#Booting_an_RTEMS_Application
> for using Luca Abeni's eXtender but end up with the following error:
> C:\RTEMS\PC686>x hello.exe
> MultiBoot Loading
> MultiBoot ELF
> Elf Loading.Error : (X_ELF) Kernel starts before Extended memory top
> Exec_space=0x110000 Needed Memory=145216 bytes - Kernel starts=0x100000
> Program loading failed!
> This happens with the pc386, pc386dx, pc586, and pc686 BSP's.  Anyone
> have a suggestion?  I don't plan on using MS-DOS in the final
> application but I don't have enough experience with grub to try to
> figure out how to get grub onto the internal flash.
> The actual target hardware is a Kontron AM4002
> (http://us.kontron.com/products/boards+and+mezzanines/advancedmc/process
> or/am4002.html) with 2GB of Flash, apparently connected to look like
> IDE-connect CompactFlash.
> rtems-users mailing list
> rtems-users at rtems.com
> No virus found in this incoming message.
> Checked by AVG - www.avg.com
> Version: 8.0.237 / Virus Database: 270.11.5/1979 - Release Date: 03/01/09 17:46:00
Dr Angelo Fraietta
A.Eng, A.Mus.A, BA(Hons), Ph.D.
PO Box 859
Hamilton NSW 2303
Home Page
http://www.smartcontroller.com.au/
There are those who seek knowledge for the sake of knowledge - that is
CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
     Bernard of Clairvaux (1090 - 1153)
