Serious Bug All Targets -- Please Read
    Ralf Corsepius
    ralf.corsepius at rtems.org
    Tue Mar  3 08:26:58 UTC 2009
>>>>> Hmm - AFAIK, c99 doesn't specify the exact representation
>>>>> of 'bool' / '_Bool'. It only says that
>>>>> "An object declared as type _Bool is large enough to store the
>>>>> values 0 and 1"
>>>>> Hence, there is no really safe way to access such
>>>>> an object from assembly code.
>>>> Exactly.
>>>>> I wonder if it wouldn't be better to change the
>>>>> type of _Context_Switch_necessary & friends
>>>>> to a type of known width.
>>>> IMO, no.
>>>> We should change to code into something which doesn't need to know
>>>> the size of a type, rsp. automatically gets it right.
>>> So how would you do that given the requirement
>>> that these variables need to be available to
>>> assembly code, maybe w/o a stack available?
>> E.g. by rewriting the code in question in C
> That's what the new PPC framework does.
>> w/ inline asm. This isn't always possible, but is possible on many
>> occasions, even when  stack is not available.
> w/o stack I'm not sure...
You can do something like this (Pseudo-C code):
extern bool var;
int _foo_stub(....)
   asm( ENTRY_SYMBOL(foo) );
   asm( PROCESS(var) );
   asm( RETURN );
I.e. to use a C-function wrapper/stub and insert asm-functions inside of
this function. It's a dirty hack, but it works quite well.
A real world example based on this approach in RTEMS can be found in
cpukit/score/cpu/sh/context.c.
>> It also somewhat (not always) helps to catch such size mismatches early.
>> Another possibility would be not to use _Bool for them (Which is the
>> type GCC interally uses), but to use an "int"
> Well - that's what I originally proposed (int32_t actually).
> IMO changing the type of these critical variables from bool -> int32_t
> is least intrusive and probably the best solution for a 4.9.2
> release.
The problem with this is: Some rtems < 4.9 targets have used short
(16bit) booleans.
Ralf
