Serious Bug All Targets -- Please Read
    Ralf Corsepius
    ralf.corsepius at rtems.org
    Wed Mar  4 02:44:29 UTC 2009
>>>>>>> Hmm - AFAIK, c99 doesn't specify the exact representation
>>>>>>> of 'bool' / '_Bool'. It only says that
>>>>>>> "An object declared as type _Bool is large enough to store the
>>>>>>> values 0 and 1"
>>>>>>> Hence, there is no really safe way to access such
>>>>>>> an object from assembly code.
>>>>>> Exactly.
>>>>>>> I wonder if it wouldn't be better to change the
>>>>>>> type of _Context_Switch_necessary & friends
>>>>>>> to a type of known width.
>>>>>> IMO, no.
>>>>>> We should change to code into something which doesn't need to know
>>>>>> the size of a type, rsp. automatically gets it right.
>>>>> So how would you do that given the requirement
>>>>> that these variables need to be available to
>>>>> assembly code, maybe w/o a stack available?
>>>> E.g. by rewriting the code in question in C
>>> That's what the new PPC framework does.
>>>> w/ inline asm. This isn't always possible, but is possible on many
>>>> occasions, even when  stack is not available.
>>> w/o stack I'm not sure...
>> You can do something like this (Pseudo-C code):
>> extern bool var;
>> int _foo_stub(....)
>>   asm( ENTRY_SYMBOL(foo) );
>>   asm( PROCESS(var) );
>>   asm( RETURN );
> You can't be serious.
What's your problem with this? This is all valid C  and is not any
dirtier than using asm.
Ralf
