test build of 4.9 started
Mon Mar 9 18:45:37 UTC 2009
Kate Feng wrote:
> Joel Sherrill wrote:
>> Hi,
>> I just started a test build of the 4.9 branch.
>> If all goes well, I will cut 4.9.2 once it is
>> finished.
>> pr1385 will be closed.  I am building with
>> the latest patch.
>> If you have an outstanding issue, yell now.
> In cpukit/libmisc/dummy/dummy.c, should
> "int main( int, char **, char **); "
> be corrected as
> "int main( int, char **);"
> Is there a conflict ?
The third parameter is historically environp but I have
not come across anything definitive that states what
main is supposed to be in the C99 standard.  I see a request
to clarify it so it is either:
int main()   OR
int main(int, char **)
but apparently now it allows main to be a void as well given
the comment.
Does anyone have the standard handy?
> Kate
