about network-demos and g++
pierre kestener
pierre.kestener at cea.fr
Tue Mar 10 14:18:01 UTC 2009
Hello,
while playing with network-demos and g++, I noticed 2 small things that
could be easily changed :
- cpukit/ftpd/ftpd.h : missing c++ protection
- regarding the http example, the 2 implementations (shttpd and goahead)
use the
same init routine but with different parameters:
GoAhead: cpukit/httpd/rtems_webserver.h
int rtems_initialize_webserver();
Simple httpd: cpukit/shttpd/compat_rtems.h
rtems_status_code rtems_initialize_webserver(rtems_task_priority
initial_priority, ...
Whereas rtems_webserver.h is an installed header, compat_rtems.h is not
(no problem with gcc, but with g++ there is an error).
I think there could be a separate installed header containing this
declaration (for example rtems_webserver_shttpd.h).
best regards,
Pierre Kestener.
