How to expand the udp_sendspace
Wed Mar 18 00:36:22 UTC 2009
Busalski, Wilfried wrote:
> I need to send more than the 9216 Bytes in a udp packet.
The data passed into a send call will be broken up (fragmentation) into MTU
size packets for the physical transporting. If you send more than the MTU you
will not have a 1:1 relationship with the packets on the physical interface.
> How do I expand the size of the udp_sendspace without changing the
> source of  udp_usrreq.c ?
Did you try the setsockopt [1] and SO_SNDBUF ?
> Any Ideas ?
Take a look at the ttcp code in:
  http://www.rtems.org/ftp/pub/rtems/4.9.2/network-demos-4.9.2.tar.bz2
I think it sends large UDP packets to get the highest line rate possible.
Regards
[1] FreeBSD Man page for getsockopt
  http://www.freebsd.org/cgi/man.cgi?query=getsockopt&format=html
