RTEMS-mvme5500 BSP update
Kate Feng
feng1 at bnl.gov
Fri Mar 20 13:55:07 UTC 2009
Hi Joel,
I filed two PRs.
The patch for RTEMS4.9.1-mvme5500 BSP is PR1395.
https://www.rtems.org/bugzilla/show_bug.cgi?id=1395
The patch for RTEMS 4.8.0-mvme5500 BSP is PR1396.
https://www.rtems.org/bugzilla/show_bug.cgi?id=1396
Hope this helps,
Kate
Joel Sherrill wrote:
>>> Any chance of getting a patch to apply to the
>>> RTEMS source base?
>> The attached mvme5500-patch.tar.gz contains two files :
>> mvme5500-rtems4.8.0-2009319.diff
>> mvme5500-rtems4.9.1-20090319.diff
>> I tried to file a PR, but it seems that there are some problems
>> with the bug tracking system : bugzilla. I could not even view
>> https://www.rtems.org/bugzilla/show_bug.cgi?id=1385
>> It was OK last week, though.
> We got a new bugzilla version in an update and apparently
> it needed touching by hand.
> It is back up now. Weird update.
> --joel
>> Kate
>>> --joel sherrill
>>> RTEMS
>>> Kate Feng wrote:
>>>> Hi,
>>>> The stable version of RTEMS-mvme5500 BSP is posted at
>>>> http://www.nsls.bnl.gov/facility/expsys/software/EPICS/
>>>> The "RTEMS-mvme5500 BSP v1.4.9.1", was tested
>>>> under RTEMS 4.9.1, and the "RTEMS-mvme5500 BSP v1.4.8.0"
>>>> was tested under RTEMS 4.8.0..
>>>> The highlights of the change are :
>>>> 1) Use the GT_GPP_Value register (0xf104) instead of the
>>>> GT_GPP_Interrupt_Cause register (0xf108) to monitor the cause
>>>> of the level sensitive interrupts. See irq/BSP_irq.c.
>>>> This is an unique solution which solves part of the bugs in
>>>> the BSP, which especially affects the 1GHz network driver.
>>>> 2) There is no change in the 100 MHz network driver. Thus,
>>>> its performance stays the same. Some bugs were fixed in the
>>>> 1GHz network drivers (e.g. if_wm.c).
>>>> 3)Enable "PCI Read Agressive Prefetch", "PCI Read Line Agressive
>>>> Prefetch",
>>>> and "PCI Read Multiple Agressive Prefetch" to improve the
>>>> performance of
>>>> the PCI based applications (e.g. 1GHz network driver). See
>>>> pci/pci_interface.c.
>>>> However, performance is driven by applications.
>>>> There is no known bug at this point. Any feedback which is related to
>>>> the RTEMS-mvme5500 BSP would be highly appreciated.
>>>> Hope this helps,
>>>> Kate
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> rtems-users at rtems.com
>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
