i got error with runing ticker.exe from Quick Start
Fri Mar 20 18:32:28 UTC 2009
Ralf Corsepius wrote:
> Daron Chabot wrote:
>> From this bug report (
>> https://bugs.launchpad.net/ubuntu/+source/expat/+bug/218963 ), the fix
>> seems to a symlink, as Joel has suggested:
>> sudo ln -s /usr/lib/libexpat.so.1 /usr/lib/libexpat.so.0
>> -- dc
>> On Fri, Mar 20, 2009 at 11:04 AM, Joel Sherrill
>>>> Joel Sherrill wrote:
>>>>> Konstantin Volkov wrote:
>>>>>> directory) i got the error sparc-rtems4.10-gdb:error while loading
>>>>>> shared libraries: libexpat.so.0:
>>>>>> cannot open shared object file: No such file or directory
>>>> libexpat.so.0? Which distribution's rpm did you use to convert?
>>>>>> why it can not find the file from ticker directory (there is
>>>>>> ticket.exe in ticket directory
>>>>>> why it answered what sparc-rtems4.10-gdb is not exist comand?
>>>>> Since you used alien to convert the RPMs to Debian, you didn't
>>>>> get the dependencies processed magically for you.  I don't know
>>>>> where that library comes from on Ubuntu.
>>>> According to http://www.debian.org/distrib/packages, Debian ships
>>>> libexpat.so.1 in its libexpat1.
>>>> => The rpm based distro you used is likely incompatible to Debian/Ubuntu.
>>>> => The package you would have to install is likely called libexpat1
>>> I saw some Ubuntu traffic that other packages were having
>>> trouble even building packages because of this library
>>> and were recommending making a symlink as a fix.
> Adding a symlink between ABI incompatible shared libs never is a fix -
> It's a dirty hack.
I agree 100%.  But if it is their recommended workaround until
a real fix is in place, it is their distribution.
> Ralf
> rtems-users mailing list
> rtems-users at rtems.com
