Nios2 problems when building tests
Thu Mar 26 02:03:01 UTC 2009
Morten Kristiansen wrote:
> As a shortcut, could you send me the binary image you have, please?
Grrr.. now it isn't linking for me. Maybe I didn't get as far as I
remembered
or I have deleted the RTEMS tree. It looks close so i will work on it.
Maybe in the morning you will have something if my build finishes.
--joel
> /MK
> 2009/3/25 Roger Dahlkvist <ruppe at kth.se>:
>> Hi,
>> Yes, I defenately think the errors are memory related. I'll look at the hints you gave.
>> When I for example run hello.exe in the Altera NiosII ISS I get the following errors before the program terminates.
>> Error! : Failed memory access in component cpu_0 - Reading data 0x0 from uninitialized memory (addr = 0x1f33c)
>> Error! : Simulation failed in component cpu_0 at instruction 33372 (PC=0x8eb8 instr=0x2c000017).
>> //Roger
>> Roger Dahlkvist wrote:
>>> Thanks, any help is greatly appreciated.
>>> The status for me right now is that I have switched to newlib-1.17.0.  I also changed both cpukit/wrapup/Makefile.am and c/src/wrapup/Makefile.am, as suggested.
>>> That fixed most errors, now that both librtemscpu.a and librtemsbsp.a are added correctly.
>> Then you are probably close to in sync with what I have
>> on my laptop at home.
>>> I've tried myself to solve the remaining issues, by including /shared/bsppretaskinghook.c to libbsp.a, and define WorkAreaBase in linkcmds.
>>> However the resulting tests fail in the simulator, so that might not have been the right way to go, or there are other things to consider aswell.
>> How do the tests fail?
>> Usually at this point it is memory layout.
>> All BSPs now use the same framework for BSP initialization
>> and most use exactly the same mechanism for dividing memory
>> between the RTEMS Workspace and C program heap.
>> Can you get debug IO via printk at this point on the simulator?
>> If so, make printk work and turn on debugging in libbsp/shared/bootcard.c.
>> If not, or if it is just as easy, trace through bootcard.c in the debugger
>> and see if things look ok.
>> Also (very common), the starting stack (the one the BSP start code
>> runs on) may NOT be properly accounted for in the linkcmds and
>> your work memory (workspace and C program heap) may overlap it.
>> Then the init is clobbering the stack out from underneath you.
>> _-joel
>>> Looking forward to your inputs.
>>> //Roger
>>> ________________________________________
>>> Från: millibit at gmail.com [millibit at gmail.com] för Morten Kristiansen [millibit+rtems at gmail.com]
>>> Skickat: den 24 mars 2009 09:30
>>> Till: Joel Sherrill
>>> Kopia: Roger Dahlkvist; rtems-users at rtems.com
>>> Ämne: Re: Nios2 problems when building tests
>>> 2009/3/20 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>>> My full NIOS patches are at home.  Morten can help you
>>>> get things going.
>>> I should think so. I'll take a look at it this evening.
>>>> The biggest issue you are facing is that the NIOS II binutils
>>>> version Altera uses is TOO old for the feature used in cpukit/wrapup.
>>> I fetched the relevant versions into Subversion and tried merging. It
>>> wasn't straightforward, but as a quick solution I can create a patch
>>> that allows it to read options from a file.
>>> /MK
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>   Support Available             (256) 722-9985
