Bug with clock nanoseconds
Manuel Coutinho manuel.coutinho at edisoft.pt
Mon Mar 30 16:41:09 UTC 2009
Hi
We have discovered a bug of RTEMS relating to the clock. Even though we only
tested it for the ERC32 board (for now), we believe it is common throughout
all the targets.
The test consists in checking if the time given by rtems_clock_get is always
increasing. The code is as follows:
rtems_task Init(rtems_task_argument argument) {
    struct timespec old;
    struct timespec new;
    rtems_clock_get_uptime(&old);
    while (1) {
        rtems_clock_get_uptime(&new);
        if (new.tv_sec < old.tv_sec)
            failedTestExit(TEST_CASE, 10, "seconds decrease");
        if (new.tv_sec == old.tv_sec) {
            if (new.tv_nsec < old.tv_nsec) {
                /* this is the error given */
                printk("            new = %d %d\n", new.tv_sec,
new.tv_nsec);
                printk("            old = %d %d\n", old.tv_sec,
old.tv_nsec);
                /* commented just to continue the test */
                /*failedTestExit(TEST_CASE, 10, "second equals but
nanoseconds decreased");*/
        old = new;
        /* stop after 10 seconds */
        if (new.tv_sec > 10)
            sucessfullTestExit(TEST_CASE);
This is the output we got using the SIS simulator:
            new = 0 50002000
            old = 0 59990000
            new = 0 90002000
            old = 0 99990000
            new = 0 100003000
            old = 0 109991000
            new = 0 120003000
            old = 0 129991000
            new = 0 160002000
            old = 0 169989000
            new = 0 210002000
            old = 0 219989000
            new = 0 260002000
            old = 0 269990000
            new = 0 300001000
            old = 0 309989000
            new = 0 320003000
            old = 0 329991000
            new = 0 360002000
            old = 0 369990000
            new = 0 370002000
            old = 0 379989000
            new = 0 380001000
            old = 0 389989000
            new = 0 420002000
            old = 0 429990000
            new = 0 470002000
            old = 0 479989000
            new = 0 500004000
            old = 0 509991000
            new = 0 520001000
            old = 0 529989000
            new = 0 550003000
            old = 0 559991000
            new = 0 600002000
            old = 0 609990000
            new = 0 650002000
            old = 0 659989000
            new = 0 670001000
            old = 0 679988000
            new = 0 690002000
            old = 0 699990000
            new = 0 730002000
            old = 0 739989000
            new = 0 770001000
            old = 0 779989000
            new = 0 790004000
            old = 0 799992000
            new = 0 800001000
            old = 0 809989000
            new = 0 840001000
            old = 0 849989000
            new = 0 860004000
            old = 0 869991000
            new = 0 870001000
            old = 0 879989000
            new = 0 890004000
            old = 0 899991000
            new = 0 900001000
            old = 0 909989000
            new = 0 920004000
            old = 0 929991000
            new = 0 930001000
            old = 0 939989000
            new = 0 950004000
            old = 0 959992000
            new = 0 960001000
            old = 0 969989000
            new = 1 40002000
            old = 1 49990000
            new = 1 60002000
As you can see, the problem is raised when a clock tick occurs: the time
read in "new" is older than "old". This cannot happen since "new" is updated
AFTER "old"! This problem occurs if a clock interrupt is triggered after the
number of clock ticks have been read but BEFORE the nanosecond field has
been read. The resulting number of clock ticks is "small" (should be plus
one).
We can use the interrupt pending CPU registers info to determine if, while
we are reading the number of clock ticks that occurred and the nanoseconds,
a clock interrupt could be pending.
We do not have enough knowledge to say that this solution can be used for
all boards (determining if an interrupt is pending). In the SPARC
architecture, at least, it is possible. If it is possible in all
architectures, then a solution to RTEMS would be to change the code of the
_TOD_Get_uptime function to:
void _TOD_Get_uptime(struct timespec *uptime) {
    ISR_Level level;
    struct timespec offset;
    volatile uint32_t pending;
    /* assume uptime checked by caller */
    offset.tv_sec = 0;
    offset.tv_nsec = 0;
    _ISR_Disable(level);
    *uptime = _TOD_Uptime;
    if (_Watchdog_Nanoseconds_since_tick_handler)
        offset.tv_nsec = (*_Watchdog_Nanoseconds_since_tick_handler)();
    /* code added: */
    pending = isClockInterruptPending();
    _ISR_Enable(level);
    /* code added */
    /* if an interrupt occurred while interrupts were disabled and the
nanoseconds is too little */
    /* means that a clock interrupt occurred BEFORE the nanoseconds were
read */
    if (pending && offset.tv_nsec <
rtems_configuration_get_microseconds_per_tick() / 2) {
        struct timespec clockTick = {0,
rtems_configuration_get_microseconds_per_tick()*1000};
        _Timespec_Add_to(&offset, &clockTick); /* so add one clock tick to
the offset */
    /* else, the clock tick occurred AFTER the nanoseconds were read, so no
problem */
    _Timespec_Add_to(uptime, &offset);
At least, with these modifications, the test passes :)!
Kind regards
Manuel Coutinho
URL: <http://lists.rtems.org/pipermail/users/attachments/20090330/78ac94b8/attachment.html>
