Bug with clock nanoseconds
Tue Mar 31 10:39:54 UTC 2009
Aitor Viana wrote:
> Yep,
> crystal clear. BTW, isClockInterruptPending() is not present in the
> RTEMS distribution, it should be implemented for all BSPs I guess.
I repeat.  It is the responsibility of the clock tick device driver
to reliably and correctly report the number of nanoseconds since
the last time rtems_clock_tick was called.  If that was slightly
greater than 1 tick ago, then it needs to return a number of nanoseconds
slightly greater than 1 tick.
Any code modifications outside the device driver are not correct and
will not address all cases of using this extension.
This might be a common issue with get nanoseconds handlers but it will
NOT be addressed in this way.  Check the is pending bit or that the
counter overflowed in the get nanoseconds handler and return the correct
number.
--joel
> Best regards,
> Aitor
> On Tue, Mar 31, 2009 at 10:30 AM, Manuel Coutinho
> <manuel.coutinho at edisoft.pt <mailto:manuel.coutinho at edisoft.pt>> wrote:
>     Hi. Thanks for testing in leon2…was just about to do that :)!
>     Basically, the test aims to see that the clock is always
>     increasing. But the result is that, sometimes, it decreases.
>     This happens when a clock tick occurs.
>     The RTEMS algorithm to read the time consists of:
>     1. Disabling interrupts
>     2. Read how many clock interrupts occurred
>     3. Read nanoseconds elapsed
>     4. Enable interrupts
>     The problem occurs if an interrupt occurs between the 1 and 3
>     steps: -> the number of clock ticks is NOT updated (because
>     interrupts are disabled) and the nanoseconds field (which is read
>     directly from the CPU registers) is restarted.
>     For example, the clock is 2 clock ticks and 99999 us (a clock tick
>     is just about to occur). Suppose you disable interrupts, read 2
>     clock ticks, then the CPU clock counter overflows and the
>     nanoseconds is reset to 0 and you read 0 nanoseconds.
>     You end up reading 2 clock ticks and 0 nanoseconds when in fact
>     you should read 3 clock ticks and 0 nanoseconds - you cannot stop
>     the clock counter (nor do you wish to!).
>     Hope this explains the problem a little bit better :)
>     By the way, by glancing at the code of the remaining BSPs,
>     specifically at the Clock_driver_nanoseconds_since_last_tick
>     macro, I don’t believe this is a problem just with SPARC. I don’t
>     see this problem address in any board. But, of course, I might be
>     wrong since it was just a very brief look.
>     Kind regards
>     Manuel Coutinho
>     *From:* aitorvs at googlemail.com <mailto:aitorvs at googlemail.com>
>     [mailto:aitorvs at googlemail.com <mailto:aitorvs at googlemail.com>]
>     *On Behalf Of *Aitor Viana
>     *Sent:* Tuesday, March 31, 2009 8:31 AM
>     *To:* Joel Sherrill
>     *Cc:* Manuel Coutinho; rtems-users at rtems.com
>     <mailto:rtems-users at rtems.com>
>     *Subject:* Re: Bug with clock nanoseconds
>     Just tried in tsim-leon and happens the same.
>     I didn't completely understand what's the problem Manuel could you
>     explain to me again? is early in the morning :D
>     Best regards,
>     Aitor
>     On Mon, Mar 30, 2009 at 6:49 PM, Joel Sherrill
>     <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>     Manuel Coutinho wrote:
>     > Hi
>     > We have discovered a bug of RTEMS relating to the clock. Even though
>     > we only tested it for the ERC32 board (for now), we believe it is
>     > common throughout all the targets.
>     No you have discovered a bug in the ERC32's get nanoseconds since last
>     tick handler.
>     Apparently it doesn't recognize that is has been longer than a tick
>     since the last clock
>     tick.  It should determine that is has overflowed and return 1 clock
>     tick + partial clock
>     tick.
>     It is returning the wrong answer.
>     > The test consists in checking if the time given by rtems_clock_get is
>     > always increasing. The code is as follows:
>     > As you can see, the problem is raised when a clock tick occurs: the
>     > time read in “new” is older than “old”. This cannot happen since
>     “new”
>     > is updated AFTER “old”! This problem occurs if a clock interrupt is
>     > triggered after the number of clock ticks have been read but BEFORE
>     > the nanosecond field has been read. The resulting number of clock
>     > ticks is “small” (should be plus one).
>     > We can use the interrupt pending CPU registers info to determine if,
>     > while we are reading the number of clock ticks that occurred and the
>     > nanoseconds, a clock interrupt could be pending.
>     > We do not have enough knowledge to say that this solution can be used
>     > for all boards (determining if an interrupt is pending). In the SPARC
>     > architecture, at least, it is possible. If it is possible in all
>     > architectures, then a solution to RTEMS would be to change the
>     code of
>     > the _TOD_Get_uptime function to:
>     > void _TOD_Get_uptime(struct timespec *uptime) {
>     >     ISR_Level level;
>     >     struct timespec offset;
>     >     volatile uint32_t pending;
>     >     /* assume uptime checked by caller */
>     >     offset.tv_sec = 0;
>     >     offset.tv_nsec = 0;
>     >     _ISR_Disable(level);
>     >     *uptime = _TOD_Uptime;
>     >     if (_Watchdog_Nanoseconds_since_tick_handler)
>     >         offset.tv_nsec =
>     (*_Watchdog_Nanoseconds_since_tick_handler)();
>     >     /* code added: */
>     >     pending = isClockInterruptPending();
>     >     _ISR_Enable(level);
>     >     /* code added */
>     >     /* if an interrupt occurred while interrupts were disabled
>     and the
>     > nanoseconds is too little */
>     >     /* means that a clock interrupt occurred BEFORE the nanoseconds
>     > were read */
>     >     if (pending && offset.tv_nsec <
>     > rtems_configuration_get_microseconds_per_tick() / 2) {
>     >         struct timespec clockTick = {0,
>     > rtems_configuration_get_microseconds_per_tick()*1000};
>     >         _Timespec_Add_to(&offset, &clockTick); /* so add one clock
>     > tick to the offset */
>     >     /* else, the clock tick occurred AFTER the nanoseconds were read,
>     > so no problem */
>     >     _Timespec_Add_to(uptime, &offset);
>     > At least, with these modifications, the test passes :)!
>     > Kind regards
>     > Manuel Coutinho
>     Joel Sherrill, Ph.D.             Director of Research & Development
>     joel.sherrill at OARcorp.com        On-Line Applications Research
>     Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>       Support Available             (256) 722-9985
>     _______________________________________________
>     rtems-users mailing list
>     rtems-users at rtems.com <mailto:rtems-users at rtems.com>
>     http://rtems.rtems.org/mailman/listinfo/rtems-users
