Bug with clock nanoseconds
Aitor.Viana.Sanchez at esa.int
Tue Mar 31 13:38:40 UTC 2009
> It is correct. RTEMS asked the BSP a very simple question:
> "How many nanoseconds has it been since you last called
rtems_clock_tick?"
> The driver was answering this question with the "number of nanoseconds
> since the last counter hit zero" not since it last called
rtems_clock_tick.
In this case I think is correct as the "counter hit zero" event
corresponds to the "last called rtems_clock_tick()"
> You are losing the ability to have the timestamp include "partial
ticks".
> If you call get uptime 10 times in a row, you will likely get only 1 or
two
> (if a tick occurs) distinct values. Getting nanosecond accurate
timestamps
> is the entire functional goal of the handler being called.
Yes that's completely true. I want to ask something. The problem is caused
because _TOD_Get_uptime() function is performing...
*uptime = _TOD_Uptime
if( _Watchdog_Nanoseconds_since_tick_handler )
offset.tv_nsec = (*_Watchdog_Nanoseconds_since_tick_handler)();
and if a clock tick interrupt occurs in between the consistency between
the uptime and offset values is lost. Should not be the _TOD_Get_uptime()
function preventing this?
URL: <http://lists.rtems.org/pipermail/users/attachments/20090331/5d481d81/attachment.html>
