Telnetd initialization changes
    Ralf Corsepius
    ralf.corsepius at rtems.org
    Tue Mar  3 08:29:22 UTC 2009
Till Straumann wrote:
> Sebastian Huber wrote:
>> Hi,
>> here is the patch that tries to refactor the login code:
>> https://www.rtems.org/bugzilla/attachment.cgi?id=639
> I've been away and was unable to comment.
> I think most of your proposed changes are OK
> but I generally have a problem with API changes.
> Even though rtems_telnetd_initialize() is kind
> of ugly and doesn't cover all the configurable
> parameters I am opposed to changing its arguments
> for sake of compatibility with existing code.
> Instead, we could introduce a 'config' structure
> where all the configurable bits can be set up
> and a new entry point for configuration + initialization.
Agreed.
> The old API could be deprecated and removed in the
> future.
Also agreed.
That said, IMO this change would be OK for rtems-4.10, but is not OK for
rtems4.9 - There, API compatibility must be kept.
Ralf
