Nios2 problems when building tests
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Mar 26 11:20:46 UTC 2009
Joel Sherrill wrote:
> Morten Kristiansen wrote:
>> As a shortcut, could you send me the binary image you have, please?
> Grrr.. now it isn't linking for me. Maybe I didn't get as far as I
> remembered
> or I have deleted the RTEMS tree. It looks close so i will work on it.
> Maybe in the morning you will have something if my build finishes.
My changes that should be committed now are. Attached
is a patch for the Makefile's so we don't use a file list and
work with the old ar command.
The starting stack is CLEARLY at the end of RAM in the
start/start.S and startup/linkcmds. This is used as
work area so getting clobbered early.
Attached in a private email is my hello if you want to look at
it but we know the stack is broken.
> --joel
>> /MK
>> 2009/3/25 Roger Dahlkvist <ruppe at kth.se>:
>>> Hi,
>>> Yes, I defenately think the errors are memory related. I'll look at the hints you gave.
>>> When I for example run hello.exe in the Altera NiosII ISS I get the following errors before the program terminates.
>>> Error! : Failed memory access in component cpu_0 - Reading data 0x0 from uninitialized memory (addr = 0x1f33c)
>>> Error! : Simulation failed in component cpu_0 at instruction 33372 (PC=0x8eb8 instr=0x2c000017).
>>> //Roger
>>> Roger Dahlkvist wrote:
>>>> Thanks, any help is greatly appreciated.
>>>> The status for me right now is that I have switched to newlib-1.17.0. I also changed both cpukit/wrapup/Makefile.am and c/src/wrapup/Makefile.am, as suggested.
>>>> That fixed most errors, now that both librtemscpu.a and librtemsbsp.a are added correctly.
>>> Then you are probably close to in sync with what I have
>>> on my laptop at home.
>>>> I've tried myself to solve the remaining issues, by including /shared/bsppretaskinghook.c to libbsp.a, and define WorkAreaBase in linkcmds.
>>>> However the resulting tests fail in the simulator, so that might not have been the right way to go, or there are other things to consider aswell.
>>> How do the tests fail?
>>> Usually at this point it is memory layout.
>>> All BSPs now use the same framework for BSP initialization
>>> and most use exactly the same mechanism for dividing memory
>>> between the RTEMS Workspace and C program heap.
>>> Can you get debug IO via printk at this point on the simulator?
>>> If so, make printk work and turn on debugging in libbsp/shared/bootcard.c.
>>> If not, or if it is just as easy, trace through bootcard.c in the debugger
>>> and see if things look ok.
>>> Also (very common), the starting stack (the one the BSP start code
>>> runs on) may NOT be properly accounted for in the linkcmds and
>>> your work memory (workspace and C program heap) may overlap it.
>>> Then the init is clobbering the stack out from underneath you.
>>> _-joel
>>>> Looking forward to your inputs.
>>>> //Roger
>>>> ________________________________________
>>>> Från: millibit at gmail.com [millibit at gmail.com] för Morten Kristiansen [millibit+rtems at gmail.com]
>>>> Skickat: den 24 mars 2009 09:30
>>>> Till: Joel Sherrill
>>>> Kopia: Roger Dahlkvist; rtems-users at rtems.com
>>>> Ämne: Re: Nios2 problems when building tests
>>>> 2009/3/20 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>>>> My full NIOS patches are at home. Morten can help you
>>>>> get things going.
>>>> I should think so. I'll take a look at it this evening.
>>>>> The biggest issue you are facing is that the NIOS II binutils
>>>>> version Altera uses is TOO old for the feature used in cpukit/wrapup.
>>>> I fetched the relevant versions into Subversion and tried merging. It
>>>> wasn't straightforward, but as a quick solution I can create a patch
>>>> that allows it to read options from a file.
>>>> /MK
>>> Joel Sherrill, Ph.D. Director of Research & Development
>>> joel.sherrill at OARcorp.com On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>> Support Available (256) 722-9985
> rtems-users mailing list
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20090326/f4b1cec5/attachment-0001.ksh>
