Yep,
crystal clear. BTW, isClockInterruptPending() is not present in the RTEMS
distribution, it should be implemented for all BSPs I guess.
Best regards,
Aitor
On Tue, Mar 31, 2009 at 10:30 AM, Manuel Coutinho <
manuel.coutinho at edisoft.pt> wrote:
> Hi. Thanks for testing in leon2…was just about to do that :)!
> Basically, the test aims to see that the clock is always increasing. But
> the result is that, sometimes, it decreases.
> This happens when a clock tick occurs.
> The RTEMS algorithm to read the time consists of:
> 1. Disabling interrupts
> 2. Read how many clock interrupts occurred
> 3. Read nanoseconds elapsed
> 4. Enable interrupts
> The problem occurs if an interrupt occurs between the 1 and 3 steps: -> the
> number of clock ticks is NOT updated (because interrupts are disabled) and
> the nanoseconds field (which is read directly from the CPU registers) is
> restarted.
> For example, the clock is 2 clock ticks and 99999 us (a clock tick is just
> about to occur). Suppose you disable interrupts, read 2 clock ticks, then
> the CPU clock counter overflows and the nanoseconds is reset to 0 and you
> read 0 nanoseconds.
> You end up reading 2 clock ticks and 0 nanoseconds when in fact you should
> read 3 clock ticks and 0 nanoseconds - you cannot stop the clock counter
> (nor do you wish to!).
> Hope this explains the problem a little bit better :)
> By the way, by glancing at the code of the remaining BSPs, specifically at
> the Clock_driver_nanoseconds_since_last_tick macro, I don’t believe this is
> a problem just with SPARC. I don’t see this problem address in any board.
> But, of course, I might be wrong since it was just a very brief look.
> Kind regards
> Manuel Coutinho
> *From:* aitorvs at googlemail.com [mailto:aitorvs at googlemail.com] *On Behalf
> Of *Aitor Viana
> *Sent:* Tuesday, March 31, 2009 8:31 AM
> *To:* Joel Sherrill
> *Cc:* Manuel Coutinho; rtems-users at rtems.com
> *Subject:* Re: Bug with clock nanoseconds
> Just tried in tsim-leon and happens the same.
> I didn't completely understand what's the problem Manuel could you explain
> to me again? is early in the morning :D
> Best regards,
> Aitor
> On Mon, Mar 30, 2009 at 6:49 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
> wrote:
> Manuel Coutinho wrote:
> > Hi
> > We have discovered a bug of RTEMS relating to the clock. Even though
> > we only tested it for the ERC32 board (for now), we believe it is
> > common throughout all the targets.
> No you have discovered a bug in the ERC32's get nanoseconds since last
> tick handler.
> Apparently it doesn't recognize that is has been longer than a tick
> since the last clock
> tick. It should determine that is has overflowed and return 1 clock
> tick + partial clock
> tick.
> It is returning the wrong answer.
> > The test consists in checking if the time given by rtems_clock_get is
> > always increasing. The code is as follows:
> > As you can see, the problem is raised when a clock tick occurs: the
> > time read in “new” is older than “old”. This cannot happen since “new”
> > is updated AFTER “old”! This problem occurs if a clock interrupt is
> > triggered after the number of clock ticks have been read but BEFORE
> > the nanosecond field has been read. The resulting number of clock
> > ticks is “small” (should be plus one).
> > We can use the interrupt pending CPU registers info to determine if,
> > while we are reading the number of clock ticks that occurred and the
> > nanoseconds, a clock interrupt could be pending.
> > We do not have enough knowledge to say that this solution can be used
> > for all boards (determining if an interrupt is pending). In the SPARC
> > architecture, at least, it is possible. If it is possible in all
> > architectures, then a solution to RTEMS would be to change the code of
> > the _TOD_Get_uptime function to:
> > void _TOD_Get_uptime(struct timespec *uptime) {
> > ISR_Level level;
> > struct timespec offset;
> > volatile uint32_t pending;
> > /* assume uptime checked by caller */
> > offset.tv_sec = 0;
> > offset.tv_nsec = 0;
> > _ISR_Disable(level);
> > *uptime = _TOD_Uptime;
> > if (_Watchdog_Nanoseconds_since_tick_handler)
> > offset.tv_nsec = (*_Watchdog_Nanoseconds_since_tick_handler)();
> > /* code added: */
> > pending = isClockInterruptPending();
> > _ISR_Enable(level);
> > /* code added */
> > /* if an interrupt occurred while interrupts were disabled and the
> > nanoseconds is too little */
> > /* means that a clock interrupt occurred BEFORE the nanoseconds
> > were read */
> > if (pending && offset.tv_nsec <
> > rtems_configuration_get_microseconds_per_tick() / 2) {
> > struct timespec clockTick = {0,
> > rtems_configuration_get_microseconds_per_tick()*1000};
> > _Timespec_Add_to(&offset, &clockTick); /* so add one clock
> > tick to the offset */
> > /* else, the clock tick occurred AFTER the nanoseconds were read,
> > so no problem */
> > _Timespec_Add_to(uptime, &offset);
> > At least, with these modifications, the test passes :)!
> > Kind regards
> > Manuel Coutinho
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
> rtems-users mailing list
URL: <http://lists.rtems.org/pipermail/users/attachments/20090331/91f52ae6/attachment-0001.html>
