Bug with clock nanoseconds
Aitor.Viana.Sanchez at esa.int
Tue Mar 31 12:06:09 UTC 2009
> I repeat. It is the responsibility of the clock tick device driver
> to reliably and correctly report the number of nanoseconds since
> the last time rtems_clock_tick was called. If that was slightly
> greater than 1 tick ago, then it needs to return a number of nanoseconds
> slightly greater than 1 tick.
I agree but...
I think bsp_clock_nanoseconds_since_last_tick() for LEON2 and ERC32 are
well implemented. They return the precise amount of nanoseconds since last
tick and I dont really see the proposed workaround (see bellow)
LEON2:
uint32_t bsp_clock_nanoseconds_since_last_tick(void) {
uint32_t clicks;
clicks = LEON_REG.Timer_Counter_1;
/* Down counter */
clicks = (uint32_t) (BSP_Configuration.microseconds_per_tick - clicks)
1000;
/* if an interrupt occurred while interrupts were disabled and the
nanoseconds is too little */
/* means that a clock interrupt occurred BEFORE the nanoseconds were
read */
if (LEON_Is_interrupt_pending(LEON_INTERRUPT_TIMER1) && clicks <
BSP_Configuration.microseconds_per_tick / 2)
clicks += BSP_Configuration.microseconds_per_tick * 1000;
return clicks;
This implementation does not make sense without the framework of the
_TOD_Get_uptime() function where the problem is an interrupt between
getting _TOD_Uptime and getting nanoseconds since last tick.
Moreover, CONFIGURE_MICROSECONDS_PER_TICK defines the RTEMS time
granularity so I dont see the point making this ad-hoc modification in
bsp_clock_nanoseconds_since_last_tick() function to make _TOD_Get_Uptime()
work properly when we can do it applying this simple patch
=== modified file 'cpukit/score/src/coretodgetuptime.c'
--- cpukit/score/src/coretodgetuptime.c 2009-03-31 07:56:38 +0000
+++ cpukit/score/src/coretodgetuptime.c 2009-03-31 11:58:51 +0000
@@ -46,8 +46,8 @@
_ISR_Disable( level );
*uptime = _TOD_Uptime;
- if ( _Watchdog_Nanoseconds_since_tick_handler )
- offset.tv_nsec = (*_Watchdog_Nanoseconds_since_tick_handler)();
+// if ( _Watchdog_Nanoseconds_since_tick_handler )
+// offset.tv_nsec = (*_Watchdog_Nanoseconds_since_tick_handler)();
_ISR_Enable( level );
loosing no resolution.
BTW this patch is tested and working.
URL: <http://lists.rtems.org/pipermail/users/attachments/20090331/f4793660/attachment-0001.html>
