POSIX signal handling
Tue Mar 31 18:22:54 UTC 2009
Sérgio Santos wrote:
> And now the handler executes just fine in the example!! So thank you for that!
> I have to let until tomorrow a more complete analysis (in terms of our app instead of the example). I will then post our comments (if any!).
Just remember there is a process set of signals/mask and a per thread
set of signals/mask.  Process signals go to the first thread that is
interested
with first being a relative term.  There is a hierarchy based upon state
and priority.
--joel
> Best regards,
> Sérgio
>> -----Original Message-----
>> From: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
>> Sent: terça-feira, 31 de Março de 2009 17:06
>> To: Sérgio Santos
>> Cc: rtems-users at rtems.com
>> Subject: Re: POSIX signal handling
>> How about this version?
>> RTEMS is multi-threaded within a single process and no thread
>> had ever enabled SIGALRM.
>> This MIGHT be a buglet in relation to the default signal mask
>> but we would have to consult the Open Group specification to
>> be sure.
>>> Thanks again for your kind answer.
>>> Actually we've had that very output... since the beginning :)
>>> Ever since the problem for us is we're expecting not the signal to be
>> pending, but otherwise that the handler *sig_handler* runs when the signal
>> is received!
>>> We're running the same code, and - glad to know by comparing - no
>> problems coming from our makefile. So we'd expect something like the
>> output in Linux (every second):
>>> [sbrotas at imaserver2 sigact]$ ./sigact
>>> HANDLER: caught SIGALRM
>>> SIGALRM not pending :)
>>> ^C
>>> Best Regards
>>> Sérgio
>>>> Sent: terça-feira, 31 de Março de 2009 14:11
>>>> To: Sérgio Santos
>>>>> Hi, Joel
>>>>> I'm using qemu (mostly) but have tried running directly on the target
>>>> too.
>>>>> Our current guess is some build configuration conflict or mistake, but
>>>> we're still to find what exactly. Still, we haven't debugged much for
>> some
>>>> clues or looked at the rtems code.
>>>> Runs for me.  I attached my version of your code and the
>>>> Makefile.
>>>> Built on an installed BSP like this:
>>>>  RTEMS_MAKEFILE_PATH=/home/joel/rtems-4.10-work/bsp-install/i386-
>>>> rtems4.10/pc386
>>>> make clean all
>>>> [joel at iceland sigaction]$ runqemu -i */*exe
>>>> Running o-optimize/sigaction.exe
>>>> Could not open '/dev/kqemu' - QEMU acceleration layer not activated: No
>>>> such file or directory
>>>> SIGALRM is pending
>>>> SIGALRM is pending
>>>> SIGALRM is pending
>>>> SIGALRM is pending
>>>> SIGALRM is pending
>>>> SIGALRM is pending
>>>> /home/joel/bin/runqemu: line 65: 15963 Killed                  ${QEMU}
>>>> ${ARGS}
>>>> SIGALRM is pending
>>>>> Our option is now getting closer to drop POSIX and go for the RTEMS
>>>> classic API on the async signals matter in particular, and for the port
>> of
>>>> our Linux app overall. Still we'll report any findings.
>>>>> Thank you much
>>>>> Sérgio
>>>>>> Sent: segunda-feira, 30 de Março de 2009 20:30
>>>>>> To: Sérgio Santos
>>>>>>>> Sent: segunda-feira, 30 de Março de 2009 19:11
>>>>>>>> To: Sérgio Santos
>>>>>>>> Sergios,
>>>>>>>> I meant to ask.. Is it ok to include this in the RTEMS examples
>>>>>>>> as a simple example of alarm and signals?
>>>>>>> Joel,
>>>>>>> Sure! Can't help feeling it's a privilege, despite the simplicity of
>>>> the
>>>>>> code :) Nevertheless I must say I'd be happier if it would work at
>> all
>>>> in
>>>>>> my system! (please see below)
>>>>>>>> Joel Sherrill wrote:
>>>>>>>>> OK.. runs for me with the CVS head.
>>>>>>>>> You forget to include <rtems/confdefs.h> at the bottom after
>>>>>>>> CONFIGURE_INIT.
>>>>>>> You're right in pointing this, it was actually an unfortunate
>> typo...
>>>>>> :)  I expected as much.  :)
>>>>>>>>> And delete the timer configuration.
>>>>>>> Done already! So a conclusion is still open for me, the code is ok,
>>>>>> configuration is (now) ok, but instead of the current 4.8.1, I should
>>>> try
>>>>>> it with the CVS head (4.9.99?)
>>>>>> How are you running it?
>>>>>>> Thanks again for your help,
>>>>>>> Sérgio
>>>>>>>>> Folks .. please consider support agreements. :-D
>>>>>>>>> --joel
>>>>>>>>>> Hello all,
>>>>>>>>>> I'm using rtems 4.8.1, target is i386 (single core, with FC9),
>>>> using
>>>>>>>> bsp's between pc386 and pc686 and the RTEMS makefile templates.
>>>>>>>>>> I have been trying to port a Linux based application to RTEMS and
>>>>>> found
>>>>>>>> at some point I couldn't get POSIX signal handlers (set with
>>>> sigaction)
>>>>>> to
>>>>>>>> ever execute. From what I've read in rtems-users and user docs, no
>>>>>>>> problems should arise from using POSIX asynchronous signal handling
>>>> in
>>>>>>>> RTEMS, so my guess is I'm making some naïve mistake on code or
>>>>>>>> configuration...
>>>>>>>>>> Also, searching on the list, came across a similar problem, but
>>>> this
>>>>>>>> was a unique case and a long while ago:
>>>>>>>>>> http://www.rtems.com/ml/rtems-users/2002/september/msg00015.html
>>>>>>>>>> Unfortunately that thread was not conclusive.
>>>>>>>>>> After a few other tests I've got down to a simple test
>> application
>>>>>> (see
>>>>>>>> below), similar to the code in the post I mentioned above: a thread
>>>>>> sets
>>>>>>>> sigaction and just does alarm(1), sleep(3) in a cycle. Alike the
>>>> other
>>>>>>>> tests, in RTEMS the handler never gets to run (although the signal
>>>>>>>> (SIGALRM) is seen pending); in Linux all tests will work.
>>>>>>>>>> POSIX was enabled in the build configuration:
>>>>>>>>>> ../../../rtems-4.8.1/c/configure --prefix=/opt/rtems-4.8 --
>>>> host=i386-
>>>>>>>> rtems4.8 --build=i686-pc-linux-gnu --target=i386-rtems4.8 --enable-
>>>>>> posix -
>>>>>>>> -disable-itron --enable-networking --enable-cxx --enable-rtems-
>> debug
>>>>>>>> enable-rdbg --enable-rtemsbsp=pc386 --with-target-subdir=i386-
>>>> rtems4.8
>>>>>>>> exec-prefix=/opt/rtems-4.8/i386-rtems4.8 --includedir=/opt/rtems-
>>>>>> 4.8/i386-
>>>>>>>> rtems4.8/include --cache-file=/dev/null --srcdir=../../../rtems-
>>>> 4.8.1/c
>>>>>>>>>> I post below the src for the simple test, having the RTEMS
>>>>>> definitions
>>>>>>>> in the end.
>>>>>>>>>> Thanks in advance for your help!
>>>>>>>>>> Sérgio Santos
>>>>>>>>>> #include <signal.h>
>>>>>>>>>> #include <stdio.h>
>>>>>>>>>> #include <unistd.h>
>>>>>>>>>> #include <stdlib.h>
>>>>>>>>>> #include <bsp.h>
>>>>>>>>>> void sig_handler(int sig){
>>>>>>>>>> 	switch(sig){
>>>>>>>>>> 	case SIGALRM:
>>>>>>>>>> 		printf("HANDLER: caught SIGALRM\n");
>>>>>>>>>> 		break;
>>>>>>>>>> 	default:
>>>>>>>>>> 		printf("Received unexpected signal (%d)\nBye!", sig);
>>>>>>>>>> 		exit(1);
>>>>>>>>>> void sig_init(){
>>>>>>>>>> 	int rc;
>>>>>>>>>> 	sigset_t 			sigset;
>>>>>>>>>> 	struct sigaction 	sigact;
>>>>>>>>>> 	rc = sigemptyset(&sigset);
>>>>>>>>>> 	if (rc != 0) {
>>>>>>>>>> 		printf("Can't empty set\n");exit(1);
>>>>>>>>>> 	sigact.sa_mask 		= sigset;
>>>>>>>>>> 	sigact.sa_flags 	= 0;
>>>>>>>>>> 	sigact.sa_handler 	= &sig_handler;
>>>>>>>>>> 	rc = sigaction(SIGALRM, &sigact, NULL);
>>>>>>>>>> 	if (rc != 0) {
>>>>>>>>>> 		printf("Can't install handler\n"); exit(1);
>>>>>>>>>> void *POSIX_Init(void *arg){
>>>>>>>>>> 	int rc = 0;
>>>>>>>>>> 	sigset_t pendingset;
>>>>>>>>>> 	sig_init();
>>>>>>>>>> 	rc = sigemptyset(&pendingset);
>>>>>>>>>> 	if (rc != 0) {
>>>>>>>>>> 	while(1){
>>>>>>>>>> 		alarm(1);
>>>>>>>>>> 		sleep(3);
>>>>>>>>>> 		sigpending(&pendingset);
>>>>>>>>>> 		printf("%s\n\n", ( sigismember(&pendingset, SIGALRM) ?
>>>>>>>>>> 				"SIGALRM is pending" : "SIGALRM not pending"
>>>>>>>>>> 	return 0;
>>>>>>>>>> #define CONFIGURE_MAXIMUM_POSIX_THREADS 10
>>>>>>>>>> #define CONFIGURE_MAXIMUM_POSIX_MUTEXES 10
>>>>>>>>>> #define CONFIGURE_MAXIMUM_POSIX_TIMERS  10
>>>>>>>>>> #define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS 40
>>>>>>>>>> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>>>>>>>>>> #define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
>>>>>>>>>> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>>>>>>>>>> #define CONFIGURE_POSIX_INIT_THREAD_TABLE
>>>>>>>>>> #define CONFIGURE_INIT
>>>>>>>>>> // EOF
>>>>>>>>>> _______________________________________________
>>>>>>>>>> rtems-users mailing list
>>>>>>>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>>>>>>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>>>>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>>>>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>>>>>>    Support Available             (256) 722-9985
