doc/setup.def in RTEMS 4.9.2 and suggested Ada version ?
Simon Clubley simon.clubley at googlemail.com
Mon May 4 15:27:54 UTC 2009
On 04/05/2009, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> Simon Clubley wrote:
> > I also see from http://www.rtems.org/ftp/pub/rtems/SOURCES/4.9 that
> > the Ada patch for gcc is for 4.2.3 and not 4.3.2. I assume therefore
> > that Ada support is a problem in gcc 4.3.2, even though the Ada entry
> > in the RTEMS Wiki shows a build against 4.3.2.
>  Hmmm... look in /pub/rtems/SOURCES and you will
>  find a 4.3.2 Ada patch for RTEMS.
I've got it, thanks. (I'd found it previously, but because it didn't
have a specific rtems version in the patch name, I didn't know if it
was an older or experimental type patch.)
> > I'm using i386 and ARM BSPs.
>  Both should work find based upon the ACATS results
>  we published to gcc-testresults.
That's good to know; thanks for the information.
Simon.
Simon Clubley
