RTEMS in a Sparc LEON3 multiprocessor system.
Thu May 7 13:22:43 UTC 2009
I hope someone from Gaisler answers but they do run RTEMS
on a 4 core LEON3 configuration.  Daniel or Jiri should provide
some details.
--joel
Gustav Kynnefjäll wrote:
> Hello.
> Im doing a thesis about LEON3 as a multiprocessor and would really
> like to use RTEMS.
> However RTEMS for LEON3 are still not modified for multiprocessor.
> ________________________________________________________
> /rtems-4.10/c/src/lib/libbsp/sparc/leon3/readme
> "This BSP supports* single* LEON3-processor system"
> Are this a correct  interpretation of the readme file?
> If so, how much work is it to change RTEMS so it will function with
> LEON3 in a multiprocessor system?
> Have some one done this before and how is it done?
> A tip where to read I would be really grateful.
> Best regards
> Gustav
> 2009/5/6 <rtems-users-request at rtems.org
> <mailto:rtems-users-request at rtems.org>>
>     Send rtems-users mailing list submissions to
>            rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>     To subscribe or unsubscribe via the World Wide Web, visit
>            http://www.rtems.org/mailman/listinfo/rtems-users
>     or, via email, send a message with subject or body 'help' to
>     You can reach the person managing the list at
>            rtems-users-owner at rtems.org
>     <mailto:rtems-users-owner at rtems.org>
>     When replying, please edit your Subject line so it is more specific
>     than "Re: Contents of rtems-users digest..."
>     Today's Topics:
>       1. Re: rename issue (Chris Johns)
>       2. Re: rename issue (Ralf Corsepius)
>       3. Re: NFS against UDP (Till Straumann)
>       4. Re: NFS against UDP (Leon Pollak)
>       5. Code sharing in shared memory systems? (Axel von Engel)
>       6. Re: Code sharing in shared memory systems? (Joel Sherrill)
>       7. warning question (Joel Sherrill)
>     Message: 1
>     Date: Wed, 06 May 2009 10:10:57 +1000
>     From: Chris Johns <chrisj at rtems.org <mailto:chrisj at rtems.org>>
>     Subject: Re: rename issue
>     To: Joel Sherrill <joel.sherrill at oarcorp.com
>     <mailto:joel.sherrill at oarcorp.com>>
>     Cc: RTEMS Users <rtems-users at rtems.org
>     <mailto:rtems-users at rtems.org>>,        Ralf Corsepius
>            <ralf.corsepius at rtems.org <mailto:ralf.corsepius at rtems.org>>
>     Message-ID: <4A00D591.8020708 at rtems.org
>     <mailto:4A00D591.8020708 at rtems.org>>
>     Content-Type: text/plain; charset=ISO-8859-1; format=flowed
>     Joel Sherrill wrote:
>     >>> Looks like we are heading for a new spin of the 4.10 tools
>     >>> soon.
>     >> Yep, .... I am going to address these issues sequentially.
>     >>>   + drop - DMISSING_SYSCALL_NAMES from configure.host
>     >> Having cross-checked your proposal, I leaned to agree with your
>     proposal
>     >> and am about to launch a toolchain spin.
>     >> Please test this toolchain! Though this patch is a one-liner,
>     this step
>     >> is quite intrusive, and is not unlikely to have (so far)
>     unconsidered
>     >> side-effects.
>     > Yeah!  This one worried me.  It could easily turn up a LOT of
>     > stuff.
>     What should we be looking for ?
>     >>>   + inttypes.h warning
>     >> WIP on my part, but no patch available so far.
>     > OK.  Chris and I were on a warning hunt and these showed up
>     > in cpukit.  They will disappear again when you get the patch.
>     Which warnings will this fix ?
>     Regards
>     Chris
>     Message: 2
>     Date: Wed, 06 May 2009 02:36:18 +0200
>     From: Ralf Corsepius <ralf.corsepius at rtems.org
>     To: Chris Johns <chrisj at rtems.org <mailto:chrisj at rtems.org>>
>     Cc: RTEMS Users <rtems-users at rtems.org <mailto:rtems-users at rtems.org>>
>     Message-ID: <4A00DB82.6010301 at rtems.org
>     <mailto:4A00DB82.6010301 at rtems.org>>
>     Content-Type: text/plain; charset=UTF-8; format=flowed
>     >>>> soon.
>     your proposal
>     this step
>     unconsidered
>     >>> side-effects.
>     >> stuff.
>     Symbol clashes/conflicts related to "_"-prefixed function symbols and
>     bogus/redundant <function>_r vs. <function> calls.
>     Joel's test case had been this:
>     ../../../../../../rtems/c/src/../../cpukit/libmisc/shell/main_mwdump.c:65:
>     >> warning: format '%08llX' expects type 'long long unsigned int', but
>     >> argument
>     >> 2 has type 'uintptr_t'
>     It shows with newlib-1.17.0 based toolchains (rtems-4.10) and can
>     be reproduced with this test case:
>     #include <inttypes.h>
>     #include <stdio.h>
>     extern uintptr_t x;
>     void doit( void ) {
>      printf("0x%08" PRIXPTR " ",addr);
>     The origin of this warning is PRIXPTR being defined to "llX" on some
>     targets, while uintptr_t is a (32bit) "long".
>     The warning had been introduced by an upstream newlib patch, which was
>     supposed to provide better c99/POSIX compliance. However,  with this
>     patch applied, gcc now complains about it.
>     So, the question, I don't know the anser to, is: Whose fault is this
>     warning? Is GCC not sufficently c99/POSIX compliant or is newlib
>     bugged?
>     newlib-1.16.0 (rtems-4.9 toolchains) don't have the patch in question
>     applied, and are not subject to this issue.
>     Ralf
>     Message: 3
>     Date: Wed, 06 May 2009 02:30:27 -0700
>     From: Till Straumann <strauman at slac.stanford.edu
>     <mailto:strauman at slac.stanford.edu>>
>     Subject: Re: NFS against UDP
>     To: Leon Pollak <leonp at plris.com <mailto:leonp at plris.com>>
>     Cc: rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>     Message-ID: <4A0158B3.9090103 at slac.stanford.edu
>     <mailto:4A0158B3.9090103 at slac.stanford.edu>>
>     Leon Pollak wrote:
>     > Hello, all.
>     > I need a help from the list members, gurus in networking, as I
>     am too
>     > weak in this.
>     > I have today an application under RTEMS speaking with another
>     > application via UDP. Most of the time data exchange via our
>     simple UDP
>     > protocol is transferring big amounts of data, the rest are some
>     commands.
>     > The amounts of data are so big (for the system) that most of the
>     time
>     > CPU is processing the BSD stack operations.
>     > The customer now insists on introducing the NFS. I object,
>     explaining
>     > my objection mostly by significant increasing of required CPU power
>     > and traffic to perform the NFS protocol.
>     > The question is - am I right? Do someone has a similar
>     experience? How
>     > can I estimate the load growth even VERY roughly?
>     A few hints (NFS read operation only; write is very similar)
>     - rtems NFS implementation is fully synchronous (no read-ahead,
>      i.e., request block X, wait until block X received). Probably your
>      raw UDP communication is similar but if it does implement
>      read-ahead / caching then expect significant slowdown when
>      using NFS.
>     - For every block read, NFS requires XDR-decoding a protocol
>      header. This overhead is relatively small, especially if a large
>      block size is used (you want 8k / max. allowed by UDP). A large
>      block size also speeds up synchronous operation.
>     - The payload data is copied verbatim (w/o any byte-swapping
>      to the user's buffer). If the 'xdr_mbuf' stream is used then
>      the cost is similar to using normal UDP (copying from mbufs
>      into user buffer) -- otherwise data are copied twice (from
>      mbufs to NFS memory buffer, then again from there to user
>      buffer.
>      The behavior is compile-time configurable (nfsclient/src/rpcio.c)
>      -- by default a second copy operation is avoided.
>     -> If you use a large block size, read relatively large files
>        (>> NFS protocol header) and your current implementation
>        does not implement read-ahead/caching then I'd be surprised
>        if NFS is a lot slower. Nevertheless, you want to run a few
>        tests...
>     HTH
>     -- Till
>     > Many thanks for any comment/help.
>     > Leon
>     Message: 4
>     Date: Wed, 6 May 2009 14:46:21 +0300
>     From: Leon Pollak <leonp at plris.com <mailto:leonp at plris.com>>
>     To: "Undisclosed.Recipients": ;
>     Message-ID: <200905061446.22078.leonp at plris.com
>     <mailto:200905061446.22078.leonp at plris.com>>
>     Content-Type: text/plain; charset="iso-8859-1"
>     >   using NFS.
>     Thanks for the tip, I shall take this into account.
>     But most of the time we do writing, not reading...
>     Yes, but as i was able to understand from the last e-mails on the
>     list, the
>     Jumbo packets are not supported "out-of-the-box" today. Or am I wrong?
>     >   buffer.
>     Great. Where can I read about all this?
>     >     tests...
>     Can you say something about "writes"? I suppose the same, yes?
>     The last question - I need to be the NFS server (not client). Can you
>     recommend something for this?
>     Till, thank you very much for your time.
>     Leon
>     -------------- next part --------------
>     An HTML attachment was scrubbed...
>     URL:
>     http://www.rtems.org/pipermail/rtems-users/attachments/20090506/d1b41fdf/attachment-0001.html
>     Message: 5
>     Date: Wed, 6 May 2009 15:11:34 +0200
>     From: Axel von Engel <a.vonengel at gmail.com
>     <mailto:a.vonengel at gmail.com>>
>     Subject: Code sharing in shared memory systems?
>     To: rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>     Message-ID:
>      <44e01eee0905060611t7d9a9110n6238ef12f9619776 at mail.gmail.com
>     <mailto:44e01eee0905060611t7d9a9110n6238ef12f9619776 at mail.gmail.com>>
>     Hello everyone!
>     I am developing a simulated multiprocessor system using MIPS cores,
>     starting from a single processor system with RTEMS set up. Since the
>     goal "simply" is to have a multiprocessor system running RTEMS with
>     multiprocessing support (i.e. almost no design constraints), I
>     currently look for options to achieve this.
>     Shared memory seems to be the simplest way to communicate. In my
>     current, very basic system the address space is shared, too. This
>     leads to my question: Is it possible to run multiple RTEMS instances
>     with the code being shared?
>     My first impression is that it would be possible if I could find means
>     to use different configuration tables depending on the current node
>     ID. Any ideas on how this could be done? What else has to be
>     separated?
>     Regards
>     Axel von Engel
>     Message: 6
>     Date: Wed, 6 May 2009 08:50:21 -0500
>     From: Joel Sherrill <joel.sherrill at OARcorp.com>
>     Subject: Re: Code sharing in shared memory systems?
>     To: Axel von Engel <a.vonengel at gmail.com
>     Cc: "rtems-users at rtems.org <mailto:rtems-users at rtems.org>"
>     Message-ID: <4A01959D.70606 at oarcorp.com
>     <mailto:4A01959D.70606 at oarcorp.com>>
>     Content-Type: text/plain; charset="ISO-8859-1"; format=flowed
>     Axel von Engel wrote:
>     > Hello everyone!
>     means
>     > separated?
>     The current mptests build the same source twice but they
>     only differ in the node number.  That is used to determine
>     which node does what.  That helps with the "same code image"
>     issue but doesn't solve the problem of ensuring that
>     each node has different addresses for .data, .bss, C program
>     heap and workspace.
>     For running them on psim, each CPU is an independent instance
>     of a PowerPC with its own memory space.  A block of unix shared
>     memory is mapped into each CPU's address space for shared
>     communication.
>     There are 4 core LEON3 systems and they do a slightly different
>     setup if I remember right.  Link each node's code/data to a different
>     area of memory and reserve part of the memory for communication
>     between nodes.
>     > Regards
>     > Axel von Engel
>     Joel Sherrill, Ph.D.             Director of Research & Development
>     joel.sherrill at OARcorp.com        On-Line Applications Research
>     Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>       Support Available             (256) 722-9985
>     Message: 7
>     Date: Wed, 6 May 2009 10:49:28 -0500
>     Subject: warning question
>     To: "rtems-users at rtems.org <mailto:rtems-users at rtems.org>"
>     Message-ID: <4A01B188.2070807 at oarcorp.com
>     <mailto:4A01B188.2070807 at oarcorp.com>>
>     Hi,
>     I am looking at warnings and wondered if someone
>     could figured this one out.
>     c/src/libchip/network/i82586.c:1722: warning: suggest parentheses
>     around
>     operand of '!' or change '|' to '||' or '!' to '~'
>     The code is clearly questionable IMO. ;)
>      *IE_CMD_CFG_PROMISC(buf)   = !!promiscuous | manchester << 2;
>     Hopefully someone can help out.
>     End of rtems-users Digest, Vol 32, Issue 6
