Real Time Clock
    Sebastian Huber
    Mon May 11 11:56:33 UTC 2009
Joel Sherrill wrote:
> Sebastian Huber wrote:
>> Hi,
>> I tried to write a shell command to read and set the real time clock
>> (RTC).
>> Unfortunately this is currently impossible to achieve within the
>> cpukit.  One
>> solution would be to extend the default RTC driver interface in
>> cpukit/libcsupport/include/rtc.h:
>> #define RTC_DEVICE_NAME "/dev/rtc"
>> #define RTC_DRIVER_TABLE_ENTRY \
>>   { rtc_initialize, NULL, NULL, rtc_read, rtc_write, NULL }
>> rtems_device_driver rtc_initialize(
>>   rtems_device_major_number,
>>   rtems_device_minor_number,
>>   void *
>> rtems_device_driver rtc_read(
>>   void *
>> rtems_device_driver rtc_write(
>>   void *
>> The read and write function would read or set the RTC with a
>> rtems_time_of_day
>> structure argument.
> There are a few other IOCTL-type methods in the "RTC library
> driver".
Where is the "RTC library driver"?  I don't see more methods except read and
write as mandatory for the standard driver.
> I don't have a problem with adding some more standard interfaces
> to the driver.  It should be possible to do it in a way that doesn't
> impact any existing BSP or application.
Only two driver implement the standard interface from <rtems/rtc.h>:
c/src/lib/libbsp/shared/tod.c
c/src/lib/libcpu/bfin/clock/rtc.c
These two would need an update.
> Propose away.
>> Have a nice day!
Sebastian Huber, Embedded Brains GmbH
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
PGP     : Public key available on request
