RTEMS Class example Timer : strange behaviour (to me)
Sat May 16 17:41:16 UTC 2009
pierre kestener wrote:
> Hello,
> The problem can be reproduced using the Sparc/SIS simulator target
> with the latest CVS sources and the 4.10 toolchain. However the problem
> disappears
> when falling back to RTEMS version 4.9.
I have duplicated this and wonder if the USE_TIMER_SERVER
is NOT defined when it works and is defined when it does not.
That would indicate an issue with the task timer server code
that is likely version independent.
Please confirm this setting for your "works" and "broken" cases.
FWIW you can also do this to get the time stamp:
        { struct timespec uptime;
          rtems_clock_get_uptime( &uptime );
          fprintf( stderr, "  %d:%d\n", uptime.tv_sec, uptime.tv_nsec );
rtems_clock_get_uptime() is fairly new but handy. :)
--joel
> Can someone confirm he has the same wrong output as me for this test
> using the SIS target ?
> Wrong output of timer class example (withthe only modification to have a
> print_time following each LED print) :
> *** LED BLINKER -- timer ***
> LED OFF 00:00:01
> LED ON 00:00:02
> LED OFF 00:00:03
> LED ON 00:00:05
> LED OFF 00:00:07
> LED ON 00:00:09
> LED OFF 00:00:11
> LED ON 00:00:13
> LED OFF 00:00:15
> LED ON 00:00:17
> The first LED_ON is missing.
> Moreover it looks like after a while, the 2 timers are "sequentialized"
> instead of interleaved.
> Pierre Kestener.
> pierre kestener a écrit :
>> More about timer example problem in Leon2 BSP :
>> I have tried different couples RTEMS toochain / RTEMS src :
>> - 4.9.0 from rtems.org
>> - RCC 1.1.1 from Gaisler (RTEMS scr 4.8)
>> - RCC 1.1.99.1 from Gaisler (downloaded in Feb 2009)
>> - RCC 1.1.99.3 from Gaisler (downloaded today)
>> the problem described below only appears with the latest Gaisler
>> toolchain/src 1.1.99.x
>> everything is fine when using the release toolchain/src 4.9.0 (from
>> rtems.org) or with the older Gaisler toolchain/src couple.
>> I haven't tried a more recent toolchain/src neither the CVS sources.
>> Pierre.
>>> Hello,
>>> I am running the timer class example on real hardware (Sparc/Leon2)
>>> with printing on console.
>>> Timer1 and 2 service routines are each set with a 2 seconds interval,
>>> but I noticed that
>>> after 2 fireouts, time between 2 LED_ON (or LED OFF)  prints becomes
>>> 4 seconds.
>>> To illustrate this, I put a rtems_time_of_day  global variable named
>>> "now" in the source code to use it to print time.
>>> Here is the corresponding output :
>>> LED ON  00:00:00
>>> 01/01/2009                                                  LED OFF
>>> 00:00:01   01/01/2009
>>> LED ON  00:00:02
>>> 01/01/2009                                                  LED OFF
>>> 00:00:03   01/01/2009
>>> LED ON  00:00:05
>>> 01/01/2009                                                  LED OFF
>>> 00:00:07   01/01/2009
>>> LED ON  00:00:09
>>> 01/01/2009                                                  LED OFF
>>> 00:00:11   01/01/2009
>>> LED ON  00:00:13
>>> 01/01/2009                                                  LED OFF
>>> 00:00:15   01/01/2009
>>> LED ON  00:00:17   01/01/2009
>>> I also noticed that if I comment the line calling Timer2 service routine
>>> Timer_Routine(Timer2, NULL);
>>> in the Init task, then Timer1 is called twice and then it stops, no
>>> print anymore.
>>> LED ON  00:00:00
>>> 01/01/2009                                                  LED ON
>>> 00:00:02   01/01/2009
>>> Can someone help me and give some explanation of what seems strange
>>> to me ?
>>> Thank you in advance.
>>> Pierre Kestener.
> rtems-users mailing list
> rtems-users at rtems.org
