Possible error in coremutex.c
Mon May 18 13:42:43 UTC 2009
Manuel Coutinho wrote:
> Hi
> Joel, that was the change was thinking about (just add the brackets).
Would you mind filing the PR so you get notifications? :-D
> Kind regards
> Manuel Coutinho
>> -----Original Message-----
>> From: Chris Johns [mailto:chrisj at rtems.org]
>> Sent: Saturday, May 16, 2009 11:55 AM
>> To: Joel Sherrill
>> Cc: Manuel Coutinho; rtems-users at rtems.com
>> Subject: Re: Possible error in coremutex.c
>> Joel Sherrill wrote:
>>> If so, my reading of the code agrees with you. I would like to hear
>>> the opinion of others.
>> This looks correct to me. I wonder if this could explain the problems I
>> had last year when doing the libblock changes and I had the problem with
>> IDLE being changed in priority. Wish I could remember the issue I had.
>> Regards
>> Chris
