RTEMS programming issues
Nasim Zehra
nasimz at lums.edu.pk
Wed May 20 04:14:52 UTC 2009
Hi,
I am doing work on rate monotonic scheduling,i have to scheduale 5 periodic tasks.I am using rate monotonic directives but there are some problems and i am stuck with it.
- the issues regarding programing were to understand rate monotonic directives.
- whether to use rtems_rate_monotonic_cancel directive in every program or not.
- nanosecond/ticks option problem to select.
- get_status is creating problem,kindly try to take status more than one time in loop , error occured "unexpected trap at --- memory address"
- get_statistics is also creating problem ,run time error,
Can any one post a example for me to so that i can run it to understand the directives usage or any schedualing example other than that described in c user manual of rtems.
