Problem with running hello_world on Lite5200 eval board
Sebastian Huber
Fri May 1 08:36:47 UTC 2009
The start address of the text section is 0x10000 an not 0x40000 (used in
-a and -e mkimage options). The README.IceCube is not up to date.
Joel Sherrill wrote:
> I'm at home but there is a step past getting the executable
> where you have to use mkimage on it. The command might
> be in the list archives.
> Thomas or Sebastian might have this handier.
> --joel
> Brian Mu wrote:
>> Hi,
>> I would like to get some help on running hello_world on Lite5200 eval
>> board (icecube).
>> I downloaded and compiled u-boot-2009.03 successfully on my Fedora box
>> and tftp/flash_updated to the eval board. Here is the boot message
>> when the board is up:
>> U-Boot 2009.03 (Apr 21 2009 - 12:25:02)
>> CPU: MPC5200 v1.2, Core v1.1 at 198 MHz
>> Bus 66 MHz, IPB 33 MHz, PCI 16.500 MHz
>> Board: Motorola MPC5200 (IceCube)
>> I2C: 85 kHz, ready
>> DRAM: 64 MB
>> FLASH: 16 MB
>> PCI: Bus Dev VenId DevId Class Int
>> 00 1a 1057 5803 0680 00
>> In: serial
>> Out: serial
>> Err: serial
>> Net: FEC ETHERNET
>> IDE: Bus 0: not available
>> Type "run flash_nfs" to mount root filesystem over NFS
>> Hit any key to stop autoboot: 0
>> => tftp 90000 hello.bin
>> Using FEC ETHERNET device
>> TFTP from server 172.21.3.224; our IP address is 172.21.3.46
>> Filename 'hello.bin'.
>> Load address: 0x90000
>> Loading: #########
>> done
>> Bytes transferred = 127712 (1f2e0 hex)
>> => go 90000
>> ## Starting application at 0x00090000 ...
>> I also configure/make/installed the released branch of RTEMS 4.9 by
>> the following steps
>> Configure RTEMS for icecube
>> cd build
>> ../rtems-4.9.2/configure --target=powerpc-rtems4.9 --enable-cxx
>> --enable-networking --disable-itron --enable-rtemsbsp=icecube
>> Compile RTEMS for icecube
>> make all
>> su
>> make install
>> Compile examples
>> cd ../examples-4.9.2
>> export RTEMS_MAKEFILE_PATH=/opt/rtems-4.9/powerpc-rtems4.9/icecube/
>> make
>> I did add a section in the hello_world make file to create an image
>> file (irrelevant for now since I use 'go' directly)
>> /opt/rtems-4.9/bin/powerpc-rtems4.9-objcopy -R -S -O binary
>> ${ARCH}/hello.exe ${ARCH}/hello.bin
>> cat ${ARCH}/hello.bin | gzip -9 > ${ARCH}/hello.gz
>> /opt/eldk_42/usr/bin/mkimage \
>> -A ppc -O rtems -T kernel -a 0x40000 -e 0x40000 -n "RTEMS" \
>> -d ${ARCH}/hello.gz ${ARCH}/hello.img
>> After tftp hello.bin to 0x90000, then typing 'go 90000' under u-boot,
>> nothing gets printout. I do have a BDI3000 with me. By stepping
>> through the code, it seems that the code stuck at 0x9064c of the
>> boot_card()
>> * Set the program name in case some application cares.
>> if ((argc > 0) && argv && argv[0])
>> rtems_progname = argv[0];
>> else
>> rtems_progname = "RTEMS";
>> 10640: 3d 20 00 03 lis r9,3
>> 10644: 39 29 bc 28 addi r9,r9,-17368
>> 10648: 91 2d 04 94 stw r9,1172(r13)
>> 1064c: 4b ff ff 50 b 1059c <boot_card+0x64>
>> if (heap_start == BSP_BOOTCARD_HEAP_USES_WORK_AREA) {
>> /* Use the work area start as heap start */
>> heap_start = work_area_start;
>> I believe I am missing some obvious stuff since everything so far has
>> been straightforward. I'd appreciate if someone can point out the
>> mistake. Thanks in advance.
>> Brian
> rtems-users mailing list
> rtems-users at rtems.org
