rename issue
Ralf Corsepius
ralf.corsepius at rtems.org
Wed May 6 00:36:18 UTC 2009
Chris Johns wrote:
> Joel Sherrill wrote:
>>>> Looks like we are heading for a new spin of the 4.10 tools
>>>> soon.
>>> Yep, .... I am going to address these issues sequentially.
>>>> + drop - DMISSING_SYSCALL_NAMES from configure.host
>>> Having cross-checked your proposal, I leaned to agree with your proposal
>>> and am about to launch a toolchain spin.
>>> Please test this toolchain! Though this patch is a one-liner, this step
>>> is quite intrusive, and is not unlikely to have (so far) unconsidered
>>> side-effects.
>> Yeah! This one worried me. It could easily turn up a LOT of
>> stuff.
> What should we be looking for ?
Symbol clashes/conflicts related to "_"-prefixed function symbols and
bogus/redundant <function>_r vs. <function> calls.
>>>> + inttypes.h warning
>>> WIP on my part, but no patch available so far.
>> OK. Chris and I were on a warning hunt and these showed up
>> in cpukit. They will disappear again when you get the patch.
> Which warnings will this fix ?
Joel's test case had been this:
../../../../../../rtems/c/src/../../cpukit/libmisc/shell/main_mwdump.c:65:
>> warning: format '%08llX' expects type 'long long unsigned int', but
>> argument
>> 2 has type 'uintptr_t'
It shows with newlib-1.17.0 based toolchains (rtems-4.10) and can be reproduced with this test case:
#include <inttypes.h>
extern uintptr_t x;
void doit( void ) {
printf("0x%08" PRIXPTR " ",addr);
The origin of this warning is PRIXPTR being defined to "llX" on some
targets, while uintptr_t is a (32bit) "long".
The warning had been introduced by an upstream newlib patch, which was
supposed to provide better c99/POSIX compliance. However, with this
patch applied, gcc now complains about it.
So, the question, I don't know the anser to, is: Whose fault is this
warning? Is GCC not sufficently c99/POSIX compliant or is newlib bugged?
newlib-1.16.0 (rtems-4.9 toolchains) don't have the patch in question
applied, and are not subject to this issue.
Ralf
