Real Time Clock
Fri May 15 09:13:49 UTC 2009
Hi,
in order to support the POSIX clock_gettime(), clock_settime() and
clock_getres() functions we need a RTC driver interface which can at least read
 and set the RTC.  An interface proposal follows:
 * @file
 * Real-time clock driver interface.
 *  COPYRIGHT (c) 1989-2001.
 *  On-Line Applications Research Corporation (OAR).
 *  The license and distribution terms for this file may be
 *  found in the file LICENSE in this distribution or at
 *  http://www.rtems.com/license/LICENSE.
 *  $Id: rtc.h,v 1.4 2005/01/28 08:04:27 ralf Exp $
#ifndef _RTEMS_RTC_H
#define _RTEMS_RTC_H
#ifdef __cplusplus
extern "C" {
#endif
 * @defgroup rtems_rtc Real-Time Clock Driver Interface
 * This driver interface provides support to read and set the real-time clock
 * and to initialize the time of day for the system.
 * Device file name path.
#define RTC_DEVICE_NAME "/dev/rtc"
 * Device driver table entry.
#define RTC_DRIVER_TABLE_ENTRY \
  { rtc_initialize, rtc_open, rtc_close, \
    rtc_read, rtc_write, rtc_control }
 * Initializes the real-time clock device and sets the time of day for the
 * system.
 * If the real-time clock provides an invalid time of day value the system time
 * of day must remain untouched.
rtems_device_driver rtc_initialize(
  rtems_device_major_number,
  rtems_device_minor_number,
  void *
 * Opens the real-time clock device.
rtems_device_driver rtc_open(
  void *
 * Closes the real-time clock device.
rtems_device_driver rtc_close(
  void *
 * Reads the real-time clock value.
 * The value will be returned in a @ref rtems_time_of_day structure.
rtems_device_driver rtc_read(
  void *
 * Sets the real-time clock value.
 * The value will be set from a @ref rtems_time_of_day structure.
rtems_device_driver rtc_write(
  void *
 * Controls the real-time clock.
rtems_device_driver rtc_control(
  void *
#ifdef __cplusplus
#endif
#endif
Sebastian Huber, Embedded Brains GmbH
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
PGP     : Public key available on request
