linker problem installing rtems4.10
Daniel_M medinad at unican.es
Mon Nov 9 18:10:57 UTC 2009
Hello,
I am new with rtems and I was trying to run the quick start example.
I am on an i386 pc with Ubuntu 9.04 and I installed tools as debs
(version 4.9.99.0 aka 9.10).
I configure it like 'Example Application Compiling'
<http://www.rtems.com/wiki/index.php/Example_Application_Compiling>
I export the $PATH. execute bootstrap and create and configure a new
folder. But when I try to compile it I get the error copied down.
It is mainly a linker problem, that find 'multiple definition' of some
functions. I try to find it, but I cannot find the calls to the
functions in the file init.c. And I fell quite lost in the rtems file
structure.
Thank you for help.
Daniel M.
End of make, where error shows.
-----------8<---------------------
make[3]: Leaving directory
`/home/daniel/workspace/rtems/pc586/i386-rtems4.10/c/pc586/optman'
Making all in testsuites
make[3]: Entering directory
`/home/daniel/workspace/rtems/pc586/i386-rtems4.10/c/pc586/testsuites'
Making all in samples
make[4]: Entering directory
`/home/daniel/workspace/rtems/pc586/i386-rtems4.10/c/pc586/testsuites/samples'
Making all in hello
make[5]: Entering directory
`/home/daniel/workspace/rtems/pc586/i386-rtems4.10/c/pc586/testsuites/samples/hello'
i386-rtems4.10-gcc -B../../../../../pc586/lib/ -specs bsp_specs -qrtems
-DPACKAGE_NAME=\"rtems-c-src-tests-samples\"
-DPACKAGE_TARNAME=\"rtems-c-src-tests-samples\"
-DPACKAGE_VERSION=\"4.9.99.0\"
-DPACKAGE_STRING=\"rtems-c-src-tests-samples\ 4.9.99.0\"
-DPACKAGE_BUGREPORT=\"http://www.rtems.org/bugzilla\" -DSTDC_HEADERS=1
-DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1
-DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_INTTYPES_H=1
-DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -I.
-I../../../../../../../rtems/c/src/../../testsuites/samples/hello
-mtune=pentium -O2 -g -Wall -Wimplicit-function-declaration
-Wstrict-prototypes -Wnested-externs -MT init.o -MD -MP -MF
.deps/init.Tpo -c -o init.o
../../../../../../../rtems/c/src/../../testsuites/samples/hello/init.c
mv -f .deps/init.Tpo .deps/init.Po
-Wstrict-prototypes -Wnested-externs   -Wl,-Ttext,0x00100000
-mtune=pentium   -o hello.exe init.o
../../../../../pc586/lib/no-barrier.rel
../../../../../pc586/lib/no-dpmem.rel
../../../../../pc586/lib/no-event.rel
../../../../../pc586/lib/no-msg.rel ../../../../../pc586/lib/no-mp.rel
../../../../../pc586/lib/no-part.rel
../../../../../pc586/lib/no-region.rel
../../../../../pc586/lib/no-signal.rel
../../../../../pc586/lib/no-timer.rel
../../../../../pc586/lib/no-rtmon.rel ../../../../../pc586/lib/no-ext.rel
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.data+0x0):
multiple definition of `rtems_libio_init_helper'
init.o:/home/daniel/workspace/rtems/pc586/i386-rtems4.10/c/pc586/testsuites/samples/hello/../../../../../../../rtems/c/src/../../testsuites/samples/hello/init.c:31:
first defined here
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.data+0x4):
multiple definition of `rtems_libio_supp_helper'
first defined here
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.data+0x8):
multiple definition of `rtems_fs_init_helper'
init.o:/home/daniel/workspace/rtems/pc586/i386-rtems4.10/c/pc586/testsuites/samples/hello/../../../../../../../rtems/c/src/../../testsuites/samples/hello/init.c:32:
first defined here
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.data+0xc):
multiple definition of `rtems_libio_number_iops'
first defined here
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.bss+0x0):
multiple definition of `rtems_telnetd_maximum_ptys'
first defined here
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.data+0x10):
multiple definition of `imfs_rq_memfile_bytes_per_block'
init.o:/home/daniel/workspace/rtems/pc586/i386-rtems4.10/c/pc586/testsuites/samples/hello/../../../../../../../rtems/c/src/../../testsuites/samples/hello/init.c:33:
first defined here
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.rodata+0x0):
multiple definition of `configuration_mount_table'
first defined here
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.data+0x14):
multiple definition of `rtems_filesystem_mount_table'
first defined here
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.rodata+0x10):
multiple definition of `rtems_filesystem_mount_table_size'
first defined here
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.data+0x18):
multiple definition of `RTEMS_Malloc_Heap'
init.o:/home/daniel/workspace/rtems/pc586/i386-rtems4.10/c/pc586/testsuites/samples/hello/../../../../../../../rtems/c/src/../../testsuites/samples/hello/init.c:34:
first defined here
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.bss+0x5):
multiple definition of `rtems_unified_work_area'
first defined here
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.bss+0x8):
multiple definition of `rtems_malloc_statistics_helpers'
first defined here
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.bss+0xc):
multiple definition of `rtems_malloc_sbrk_helpers'
first defined here
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.bss+0x10):
multiple definition of `rtems_malloc_dirty_helper'
first defined here
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.data+0x1c):
multiple definition of `Initialization_tasks'
first defined here
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.data+0x40):
multiple definition of `Device_drivers'
init.o:/home/daniel/workspace/rtems/pc586/i386-rtems4.10/c/pc586/testsuites/samples/hello/../../../../../../../rtems/c/src/../../testsuites/samples/hello/init.c:35:
first defined here
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/bin/ld:
Warning: size of symbol `Device_drivers' changed from 24 in init.o to 48
in
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.data+0x80):
multiple definition of `Configuration_Initial_Extensions'
first defined here
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.data+0xa0):
multiple definition of `Configuration_RTEMS_API'
first defined here
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.data+0xd0):
multiple definition of `rtems_minimum_stack_size'
first defined here
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.data+0xd4):
multiple definition of `rtems_maximum_priority'
first defined here
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.data+0xe0):
multiple definition of `Configuration'
first defined here
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.data+0x120):
multiple definition of `_RTEMS_tasks_Initialize_user_tasks_p'
first defined here
../../../../../pc586/lib/librtemsbsp.a(console.o): In function `conSetAttr':
/home/daniel/workspace/rtems/pc586/i386-rtems4.10/c/pc586/lib/libbsp/i386/pc386/../../../../../../../../rtems/c/src/lib/libbsp/i386/pc386/console/console.c:471:
undefined reference to `rtems_termios_baud_to_number'
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/librtemscpu.a(dummy.o):(.data+0x2c):
undefined reference to `main'
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.2/../../../../i386-rtems4.10/lib/mpentium/libc.a(lib_a-makebuf.o):
In function `__smakebuf_r':
/builddir/build/BUILD/rtems-4.10-i386-rtems4.10-gcc-4.4.2/build/i386-rtems4.10/mpentium/newlib/libc/stdio/../../../../../../gcc-4.4.2/newlib/libc/stdio/makebuf.c:110:
undefined reference to `_isatty_r'
collect2: ld returned 1 exit status
make[5]: *** [hello.exe] Error 1
make[5]: Leaving directory
make[4]: *** [all-recursive] Error 1
make[4]: Leaving directory
make[3]: *** [all-recursive] Error 1
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory
`/home/daniel/workspace/rtems/pc586/i386-rtems4.10/c/pc586'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory
`/home/daniel/workspace/rtems/pc586/i386-rtems4.10/c'
make: *** [all-recursive] Error 1
- Grupo de Computadores y Tiempo Real                www.ctr.unican.es
- Dpto. de Electrónica y Computadores
- Universidad de Cantabria                           www.unican.es
- Avda. de los Castros s/n 39005-Santander (Spain)
