telnetd
Andrei Chichak
groups at chichak.ca
Mon Nov 9 21:29:58 UTC 2009
Hi All,
I'm trying to get the networking telnetd example code running on a new
4.9.2 based BSP derived from the AV5282, and I'm having problems.
My memory is set up with:
0000 0000-007F FFFF - External FLASH (2M)
1000 0000-10FF FFFF - SDRAM (16M)
2000 0000-2000 FFFF - Internal SRAM (64K)
I am booting from flash without a ROM monitor or bootloader. I have
tested the processor and BSP to work with 3 serial ports, 11
processes, SPI, and DIO, semaphores, and message passing, at 64MHz on
the program I am developing. I have made no modifications to the
network.c file in the BSP.
I built my BSP on mingw using the Chris Johns method -
../rtems-4.9.2/configure --target=m68k-rtems4.9 \
--disable-itron \
--disable-posix \
--enable-networking \
--enable-rtemsbsp=cml5282 \
--prefix=/c/opt/src/rtems/m68k
I am having problems with the ethernet portion of my app, so I dropped
back to the example to see if I could get anything working.
When I telnet to the board, the board seems to be receiving packets
according to rtems_bsdnet_show_if_stats, but never transmit anything.
The calling host never receives the MAC address as seen in arp -a.
Telnet hangs then exits with:
telnet: connect to address 10.10.10.10: Operation timed out
telnet: Unable to connect to remote host
rtems_bsdnet_show_ip_stats and rtems_bsdnet_show_icmp_stats gives me
the headers but nothing else.
************ INTERFACE STATISTICS ************
***** fs1 *****
Ethernet Address: 00:04:9F:00:5B:21
Address:10.10.10.10 Broadcast Address:10.10.10.255 Net mask:
255.255.255.0
Flags: Up Broadcast Running Simplex
Send queue limit:50 length:0 Dropped:0
Rx Interrupts:0 Rx Packet Count:5 Rx Broadcast:3
Rx Multicast:2 CRC/Align error:0 Rx Undersize:0
Rx Oversize:0 Rx Fragment:0 Rx Jabber:0
Rx 64:3 Rx 65-127:2 Rx 128-255:0
Rx 256-511:0 Rx 511-1023:0 Rx 1024-2047:0
Rx >=2048:0 Rx Octets:340 Rx Dropped:0
Rx frame OK:3 Rx CRC error:0 Rx Align error:0
FIFO Overflow:0 Rx Pause Frames:0 Rx Octets OK:192
Tx Interrupts:0 Tx Output Waits:0 Tx Realignments:0
Tx Unaccounted:0 Tx Packet Count:0 Tx Broadcast:0
Tx Multicast:0 CRC/Align error:0 Tx Undersize:0
Tx Oversize:0 Tx Fragment:0 Tx Jabber:0
Tx Collisions:0 Tx 64:0 Tx 65-127:0
Tx 128-255:0 Tx 256-511:0 Tx 511-1023:0
Tx 1024-2047:0 Tx >=2048:0 Tx Octets:0
Tx Dropped:0 Tx Frame OK:0 Tx 1 Collision:0
Tx >1 Collision:0 Tx Deferred:0 Late Collision:0
Excessive Coll:0 FIFO Underrun:0 Carrier Error:0
Tx SQE Error:0 Tx Pause Frames:0 Tx Octets OK:0
************ ICMP Statistics ************
************ IP Statistics ************
Receive and transmit buffers are allocated from SRAM by default, which
is okay, I use SDRAM for everything else. So, the MCF5282_FEC_ERDSR is
set to 2000 0000 and ETDSR is set to 2000 0100. They contain pointers
into the SDRAM, so that looks okay.
A printk shows that neither the rtemsShell or the echoShell are being
started.
Can anybody spot what the problem may be?
Thanks,
Andrei
Andrei Chichak
Systems Developer
CBF Systems Inc.
4-038 NINT Innovation Centre
11421 Saskatchewan Drive
Edmonton, Alberta
Canada
T6G 2M9
Phone: 780-628-2072
Skype: andrei.chichak
Andrei Chichak
Systems Developer
CBF Systems Inc.
Edmonton, Alberta
Canada
T6G 2M9
Phone: 780-628-2072
URL: <http://lists.rtems.org/pipermail/users/attachments/20091109/7d346ccf/attachment.html>
