RTEMS Traps and Interrupts
    Gedare Bloom
    gedare at gwu.edu
    Wed Nov 11 16:21:54 UTC 2009
Yes, the macro is a much better choice.
I think there is also some documentation in the Sparc section of the
programmer's manual.
The definitive solution is the sparc interrupt code and code comments
of the cpukit/score/cpu/sparc/rtems/score/*.h files and
cpukit/score/cpu/sparc/cpu.c (I think those are the right files,
though I can't double check at the moment).
Good luck!
Gedare
On Wed, Nov 11, 2009 at 6:13 AM, Manuel Coutinho
<manuel.coutinho at edisoft.pt> wrote:
> Yes. I think you are right. You can also use the
> SPARC_SYNCHRONOUS_TRAP(trap) definition, to make the code more clear :).
> Kind regards
> Manuel Coutinho
>> -----Original Message-----
>> From: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org]
>> On Behalf Of Gedare Bloom
>> Sent: Wednesday, November 11, 2009 1:02 AM
>> To: Jamie.Bowman at steepestascent.com; RTEMS
>> Subject: Re: RTEMS Traps and Interrupts
>> On Tue, Nov 10, 2009 at 4:34 PM, Jamie Bowman
>> <jamie.bowman at steepestascent.com> wrote:
>> > All
>> > We have been developing a system based on the SPARC Leon 2 processor
>> using
>> > RTEMS 4.8. We have successfully used the RTEMS call
>> rtems_interrupt_catch to
>> > register interrupt handlers for a number of the 15 interrupt lines on
>> the
>> > SPARC Leon 2 processor. On the SPARC Leon2 processor, interrupts are
>> > referred to as Asynchronous Traps with interrupts 1-15 being equivalent
>> to
>> > traps 0x11–0x1F.
>> > What we would like to do now is to catch a number of the lower level
>> > processor Synchronous Traps, for example the trap associated with
>> detecting
>> > an uncorrectable EDAC error when reading Data from SDRAM.
>> > Is there support within RTEMS to register such a trap handler?
>> I think it should work to install an interrupt handler as (trapnum +
>> 256).  RTEMS will install the handler in such a way that the
>> ISR_Handler routine will fudge the return program counter to act as a
>> synchronous trap.
>> -Gedare
>> > Thank you for in advance for your assistance.
>> >             Jamie
>> > _______________________________________________
>> > rtems-users mailing list
>> > rtems-users at rtems.org
>> > http://www.rtems.org/mailman/listinfo/rtems-users
