RTEMS i386 is multiprocessor ?
Daniel_M medinad at unican.es
Thu Nov 12 08:28:41 UTC 2009
Hello,
I continue trying to configure the system to run rtems but I have few
time this days. And it is sure that the libraries are the problem. No
worries.
But, by now, I need to know if RTEMS supports multiprocessor and where
is the code that starts and wakes up secondary processors. I was looking
for it but I get lost in the code.
Regards,
Daniel M.
Daniel_M wrote:
> Hi Alan, hi Joel,
> thank you for that quick answer. It compile now without any problem
> removing the cpukit package. Thank you.
> Now I have another error on execution, but I think the problem must be
> that Joel had said. Although I had to fix some libraries to be able to
> compile. And maybe this is the problem.
> ln -s libpython2.6.so.1.0 libpython2.4.so.1.0
> ln -s libexpat.so.1.5.2 libexpat.so.0
> Regards.
> Daniel M.
> Alan Cudmore wrote:
>> Hi Daniel,
>> I just had this problem 1 hour ago!
>> If you have a "cpukit" RPM installed, uninstall it and it should
>> compile fine.
>> I'm on CentOS 5 and I installed all of the RPMs for RTEMS 4.10 ( m68k
>> target ) including the cpukit RPM. That RPM is much older than the
>> current CVS trunk, and I think the linker was looking at those
>> libraries first.
>> When I removed that RPM, I was able to build the RTEMS CVS Trunk.
>> Alan
>> On Nov 9, 2009, at 1:10 PM, Daniel_M wrote:
>>> Hello,
>>> I am new with rtems and I was trying to run the quick start example.
>>> I am on an i386 pc with Ubuntu 9.04 and I installed tools as debs
>>> (version 4.9.99.0 aka 9.10).
>>> I configure it like 'Example Application Compiling'
>>> <http://www.rtems.com/wiki/index.php/Example_Application_Compiling>
>>> I export the $PATH. execute bootstrap and create and configure a new
>>> folder. But when I try to compile it I get the error copied down.
>>> It is mainly a linker problem, that find 'multiple definition' of some
>>> functions. I try to find it, but I cannot find the calls to the
>>> functions in the file init.c. And I fell quite lost in the rtems file
>>> structure.
>>> Thank you for help.
>>> Daniel M.
>>> - Grupo de Computadores y Tiempo Real                www.ctr.unican.es
>>> - Dpto. de Electrónica y Computadores
>>> - Universidad de Cantabria                           www.unican.es
>>> - Avda. de los Castros s/n 39005-Santander (Spain)
>>> rtems-users mailing list
>>> rtems-users at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-users
