4.10 Approaching
Till Straumann strauman at slac.stanford.edu
Thu Oct 1 23:10:39 UTC 2009
Ralf Corsepius wrote:
>>>>> On 09/30/2009 05:36 PM, Feng, Kate wrote:
>>>> Please advise.
>>> Are using home-grown toolchains based on the contents of
>>> ftp://ftp.rtems.org/pub/rtems/SOURCES/4.10 ?
>>> Its contents is a bit outdated, I haven't managed to keep it uptodate,
>>> because the rapid development binutils, newlib and gdb currently are
>>> subject of kept me busy otherwise (building binary toolchains). (
>>> Which OS are you using?
>> I am in the stage of having both RHEL5 and the latest
>> Ubuntu.
> Compare for my other mail.
> I would seriously advise you to use the prebuilt CentOS5 rpms on RHEL5.
> On Ubuntu, you can try "alien"ized CentOS rpms.
>>> May-be the toolchain you need already exists pre-built.
>> However, I always had to build the binary from source code just in
>> case something is missing. See the patches I sent in 2009 for the
>> tools:
>> http://www.rtems.com/ml/rtems-users/2009/february/msg00125.html
>> http://www.rtems.com/ml/rtems-users/2009/march/msg00003.html
>> They might not apply to others' applications, but they are important
>> for my applications, although it could be time consuming to
>> apply patches, rebuild and rebuild.
> Well, you might be aware that these patches of yours are controversal?
I actually would really recommend the HAVE_BLKSIZE patch - which
BTW has been recommended for a looong time; see e.g.,
libfs/src/nfsclient/README. It greatly improves stdio on any blocked
filsystem.
msdosfs and NFS already do provide the necessary blocksize information.
IMFS currently sets the blocksize to 0 for directories. zero is also
the default if a filesystem does not set/provide a blocksize.
newlib stdio correctly handles the case of a zero blocksize but
some 'fseek()' performance gain could be achieved by using
BUFSIZ/1024 in these cases.
I can't really see *anything* controversial in this case.
-- Till
> Ralf
> rtems-users mailing list
> rtems-users at rtems.org
