4.10 Approaching
Fri Oct 2 01:58:36 UTC 2009
Chris Johns wrote:
> Till Straumann wrote:
>> I actually would really recommend the HAVE_BLKSIZE patch - which
>> BTW has been recommended for a looong time; see e.g.,
>> libfs/src/nfsclient/README. It greatly improves stdio on any blocked
>> filsystem.
>> msdosfs and NFS already do provide the necessary blocksize information.
>> IMFS currently sets the blocksize to 0 for directories. zero is also
>> the default if a filesystem does not set/provide a blocksize.
>> newlib stdio correctly handles the case of a zero blocksize but
>> some 'fseek()' performance gain could be achieved by using
>> BUFSIZ/1024 in these cases.
>> I can't really see *anything* controversial in this case.
> I have just looked in my local copy of newlib-1.17.0 and ChangeLog.rtems
> has:
> 2009-02-24      Ralf Corsépius <ralf.corsepius at rtems.org>
>          * libc/unix/ttyname.c: Sync with newlib-cvs.
>          * configure.host: Add -DHAVE_BLKSIZE to newlib_cflags.
> Is this change already in newlib ? I cannot remember if I applied any of
> Ralf's patches to this or if they are clean. I seem to remember them
> being clean.
Looks like it.  My newlib cvs has this:
2009-09-22  Ralf Corsépius <ralf.corsepius at rtems.org>
        * configure.host (*-rtems*): Remove -DMISSING_SYSCALL_NAMES.
        Add -DHAVE_BLKSIZE, -D_NO_WORDEXP -D_NO_POPEN.
> FYI I have code I am working on that allows the block size to change at
> the bdbuf layer and below. Currently the coming RFS file system has
> support for changing the block size. The MSDOS file system could be
> changed to do this and so removed the way it handles the buffers. Along
> with this change I have a statvfs call to add to libcsupport. The call
> returns the file system block and the media block sizes.
> Regards
> Chris
> rtems-users mailing list
> rtems-users at rtems.org
