Netwroking problem
Daron Chabot daron.chabot at gmail.com
Wed Oct 7 18:38:19 UTC 2009
Hi Leon,
errno==11 maps onto EAGAIN.
>From the manpage, recv(2):
ERRORS
       These  are  some  standard errors generated by the socket layer.  Addi-
       tional errors may be generated and returned from the underlying  proto-
       col modules; see their manual pages.
       EAGAIN The  socket  is  marked  non-blocking  and the receive operation
              would block, or a receive timeout had been set and  the  timeout
              expired before data was received.
Does the frequency of the error occurrence scale inversely with the
timeout value ?
-- dc
On Wed, Oct 7, 2009 at 6:55 PM, Leon Pollak <leonp at plris.com> wrote:
> Hello,
> My application (PPC, rtems 4.8) receives data sent by PC (in this case) as UDP
> packages of 1400bytes. I have 1 second timeout set with
> setsockopt (so, SOL_SOCKET, SO_RCVTIMEO, &tv, sizeof tv)
> The PC sends data at about 800kB/s rate.
> Everything works fine for an arbitrary period of time.
> At some moment, my recvfrom operation exits with -1 while errno is set to 11.
> Then the operation continues and the error may occur again several times.
> When I check the traffic in wireshark sniffer I see that the largest interval
> between packets was about 40ms.
> What is the cause of this error 11?
> A lot of thanks ahead for a help.
> Leon
> rtems-users mailing list
> rtems-users at rtems.org
