building powerpc bsp...
lee funnyvoice at tlabs.ac.za
Tue Oct 13 13:12:57 UTC 2009
Hi all...
Im getting this build error...
It seems that something is referencing , something in newlib, and I dont
know why newlib does not contain that something....
owerpc-rtems4.10-gcc -B../../../../../mvme2100/lib/ -specs bsp_specs
-qrtems -mcpu=603e -Dppc603e -O2 -g -mmultiple -mstring -mstrict-align
-mcpu=603e -Dppc603e   -o hello.exe
init.o ../../../../../mvme2100/lib/no-barrier.rel ../../../../../mvme2100/lib/no-dpmem.rel ../../../../../mvme2100/lib/no-event.rel ../../../../../mvme2100/lib/no-msg.rel ../../../../../mvme2100/lib/no-mp.rel ../../../../../mvme2100/lib/no-part.rel ../../../../../mvme2100/lib/no-region.rel ../../../../../mvme2100/lib/no-signal.rel ../../../../../mvme2100/lib/no-timer.rel ../../../../../mvme2100/lib/no-rtmon.rel ../../../../../mvme2100/lib/no-ext.rel
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.sdata+0x0): multiple definition of `rtems_libio_init_helper'
init.o:(.sdata+0x0): first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.sdata+0x4): multiple definition of `rtems_libio_supp_helper'
init.o:(.sdata+0x4): first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.sdata+0x8): multiple definition of `rtems_fs_init_helper'
init.o:(.sdata+0x8): first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.sdata+0xc): multiple definition of `rtems_libio_number_iops'
init.o:(.sdata+0xc): first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.sbss+0x0): multiple definition of `rtems_telnetd_maximum_ptys'
init.o:/home/lee/rbuild11ppc/powerpc-rtems4.10/c/mvme2100/testsuites/samples/hello/../../../../../mvme2100/lib/include/rtems/confdefs.h:329: first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.sdata+0x10): multiple definition of `imfs_rq_memfile_bytes_per_block'
init.o:(.sdata+0x14): first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.rodata+0x0): multiple definition of `configuration_mount_table'
init.o:(.rodata+0x0): first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.sdata+0x14): multiple definition of `rtems_filesystem_mount_table'
init.o:(.sdata+0x18): first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.sdata+0x18): multiple definition of `rtems_filesystem_mount_table_size'
init.o:(.sdata+0x1c): first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.sdata+0x1c): multiple definition of `RTEMS_Malloc_Heap'
init.o:(.sdata+0x20): first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.sbss+0x5): multiple definition of `rtems_unified_work_area'
init.o:/home/lee/rtems/c/src/../../testsuites/samples/hello/init.c:31:
first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.sbss+0x8): multiple definition of `rtems_malloc_statistics_helpers'
first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.sbss+0xc): multiple definition of `rtems_malloc_sbrk_helpers'
init.o:(.sdata+0x24): first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.sbss+0x10): multiple definition of `rtems_malloc_dirty_helper'
init.o:/home/lee/rtems/c/src/../../testsuites/samples/hello/init.c:32:
first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.data+0x0): multiple definition of `Initialization_tasks'
init.o:(.data+0x0): first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.data+0x1c): multiple definition of `Device_drivers'
init.o:(.data+0x1c): first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/bin/ld: Warning: size of symbol `Device_drivers' changed from 24 in init.o to 48 in /opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o)
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.data+0x4c): multiple definition of `Configuration_Initial_Extensions'
init.o:(.data+0x34): first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.data+0x6c): multiple definition of `Configuration_RTEMS_API'
init.o:(.data+0x54): first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.bss+0x0): multiple definition of `Configuration_POSIX_API'
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/bin/ld: Warning: size of symbol `Configuration_POSIX_API' changed from 56 in init.o to 52 in /opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o)
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.sdata+0x20): multiple definition of `rtems_minimum_stack_size'
init.o:(.sdata+0x28): first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.sdata+0x24): multiple definition of `rtems_maximum_priority'
init.o:(.sdata+0x2c): first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.data+0x9c): multiple definition of `Configuration'
init.o:(.data+0x84): first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.sdata+0x28): multiple definition of `_RTEMS_tasks_Initialize_user_tasks_p'
init.o:(.sdata+0x30): first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.sbss+0x14): multiple definition of `_POSIX_Threads_Initialize_user_threads_p'
first defined here
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/librtemscpu.a(dummy.o):(.data+0x10): undefined reference to `main'
/opt/rtems-4.10/lib64/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/lib/m603e/libc.a(lib_a-makebuf.o): In function `__smakebuf_r':
/builddir/build/BUILD/rtems-4.10-powerpc-rtems4.10-gcc-4.4.1/build/powerpc-rtems4.10/m603e/newlib/libc/stdio/../../../../../../gcc-4.4.1/newlib/libc/stdio/makebuf.c:110: undefined reference to `_isatty_r'
collect2: ld returned 1 exit status
gmake[5]: *** [hello.exe] Error 1
gmake[5]: Leaving directory
`/home/lee/rbuild11ppc/powerpc-rtems4.10/c/mvme2100/testsuites/samples/hello'
gmake[4]: *** [all-recursive] Error 1
gmake[4]: Leaving directory
`/home/lee/rbuild11ppc/powerpc-rtems4.10/c/mvme2100/testsuites/samples'
gmake[3]: *** [all-recursive] Error 1
gmake[3]: Leaving directory
`/home/lee/rbuild11ppc/powerpc-rtems4.10/c/mvme2100/testsuites'
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory
`/home/lee/rbuild11ppc/powerpc-rtems4.10/c/mvme2100'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/home/lee/rbuild11ppc/powerpc-rtems4.10/c'
make: *** [all-recursive] Error 1
[lee at lee
rbuild11ppc]$
