Adding new board support option
Tue Oct 20 13:27:02 UTC 2009
Peter Dufault wrote:
> On Oct 20, 2009, at 5:30 , Ralf Corsepius wrote:
>> However, you should really check, if you actually want an exported/
>> global define in bspopts.h or an AM_CONDITIONAL.
> You are correct, I don't want either of them.  I am now
> unconditionally adding the new network driver and I assume it will be
> resolved at link time by the BSP user.
You do need to make sure configure.ac and Makefile.am
turn it off if networking is disabled.   Any BSP with a
NIC driver should be an example of this.
Since this isn't a required part of every executable,
building it anytime networking is enabled is OK unless
you find yourself needing to know you are running
on board A or board B which uses the same NIC but
has differences you can't detect at run-time.
If any of that makes sense. :-D
> Thanks -
> Peter
> rtems-users mailing list
> rtems-users at rtems.org
