Clock problem using newer 80Mhz uC8252 card
Phillip Sorensen
pas37 at cornell.edu
Thu Oct 22 19:17:19 UTC 2009
Hello all,
We have purchased the newer 80Mhz Arcturus Networks uCdimm 5282 (bsp
uC5282). I have added "--defsym _CPUClockSpeed=80000000"
to linker command line to change the value returned by the
bsp_get_CPU_clock_speed() function. This successfully changes the
settings for the
serial ports so the console baud rate is correct. However I discovered
that the clock was running fast (about 15 seconds per minute). Looking at
the code in the clock/clock.c file in the uC5282 BSP, I discovered that
the code assumed that the clock rate was a power of 2, and was using
the PIT prescaler to count in microseconds. Since 80 is not a power of
two, the calculation was wrong.
I have attached the patch I came up with to solve this problem. It
tries to keep the counts per microsecond as close to 1 as possible. I
have tested
that things work with my application on both the 64MHz and 80Mhz chips.
Let me know if there are any questions, or if I should open a bug report.
Phil Sorensen
CHESS
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20091022/dc95c81f/attachment.ksh>
