MCF5282 telnetd under 4.9.2
Andrei Chichak
groups at chichak.ca
Fri Oct 23 21:19:38 UTC 2009
I am working on getting the telnetd demo program from the repository
working on my 5282 board with a BSP based on the av5282 and am having
problems getting telnet to connect.
I altered the demo code to use networkconfig-mpc8313erdb.h to pick up
a static ethernet address. The address is arbitrary as I am just using
a cable between my board and my computer without the rest of the
network.
I'm not using BOOTP/DHCP, I'll leave that for later.
The problem that I am seeing is that I can initialize the network, the
routes are added, and the telnet daemon is initialized, but when I try
to telnet into the server the connection is not successful. arp -a on
the client machine shows that the request for 192.168.1.245 is going
out the proper interface but the MAC address is not filled in.
I munged init.c to loop forever doing a rtems_bsdnet_show_if_states
and sleeping for 100 ticks. It shows that, when I issue the telnet
command, I get 192 Rx Octets OK in 3 frames. So I suspect that my
board is seeing the incoming request but the rtemsShell is not
running. After the telnet times out, I reissue it but the Rx Octets
count no longer changes.
Any ideas?
Andrei
Andrei Chichak
Systems Developer
CBF Systems Inc.
4-038 NINT Innovation Centre
11421 Saskatchewan Drive
Edmonton, Alberta
Canada
T6G 2M9
Phone: 780-628-2072
Skype: andrei.chichak
Andrei Chichak
Systems Developer
CBF Systems Inc.
Edmonton, Alberta
Canada
T6G 2M9
Phone: 780-628-2072
