Rtems telnetd/shell question
Peter Dufault
dufault at hda.com
Tue Oct 27 09:31:32 UTC 2009
I'm trying to use the RTEMS shell with the RTEMS telnetd, and it hangs
when I close down telnet. If I close down the telnet session the
shell task that was spawned by telnetd gets stuck forever in
rtems_shell_line_editor() in the "empty line" logic at line 755 where
it thinks it read a blank line, tries to prompt and doesn't see the
error, and loops forever.
I'm initializing it simply, similar to an example I saw:
static void sh_wrap( char *dev, void *arg)
(void)rtems_shell_main_loop(arg);
rtems_telnetd_config_table rtems_telnetd_config = {
sh_wrap, /* Command */
NULL, /* Argument */
0, /* Priority */
RTEMS_MINIMUM_STACK_SIZE * 16, /* task stack size */
0, /* Login check */
0 /* Keep stdio of the caller */
rtems_telnetd_initialize();
I can't "exit" the telnet shell, either, it just restarts itself
without closing the telnet connection. I tried detecting the error
when the shell printed the prompt and treating it as an EOF but that
doesn't help, it must be trying to restart itself.
Peter
