help:transplant rtems to lpc3250 with vfp coprocessor
吴玉凡
zzwuyu at 163.com
Wed Oct 28 08:35:22 UTC 2009
hello all
Now,I want transplant rtems to lpc3250,which is based on arm926ej-s,with a coprocessor VFP.All seems right except VFP. At start.s,I enable the VFP and set it to fast mode with these instructions:
/*enable VFP*/
mov r0,#0x40000000
fmxr fpexc,r0
/*set VFP to RunFast mode*/
mov r0,#(1<<24)|(1<<25)
fmxr fpscr,r0
and also in cpu_asm.s(score/cpu/arm/cpu_asm.S) ,which is uesed for save and restore VFP registers.however,when I compiled, it give these messages:
Error: selected processor does not support `fmxr fpexc,r0'
Error: selected processor does not support `fmxr fpscr,r0'
In make/Bsp.cfg, I set CFLAGS =-mlittle-endian -mabi=atpcs -march=armv5te -mfpu=vfp -mfloat-abi=softfp
So I think this maybe the default toolchain don't support VFP instructions,then I compile the toolchain again, with:
../gcc-4.2.4/configure --target=arm-rtems4.8 --disable-werror --with-gnu-as --with-gnu-ld --with-newlib --with-arch=armv5 --with-abi=atpcs --with-fpu=vfp --with-float=soft --verbose --enable-threads --enable-languages="c,c++" --disable-shared --enable-__cxa_atexit --enable-gmp --enable-mpfr --disable-multilib --prefix=/home/rtems/toolchain/
However,the problem is the same.How should I do ? I hope someone can help me.This has disturbed me two weeks.
URL: <http://lists.rtems.org/pipermail/users/attachments/20091028/61648d07/attachment.html>
