PROGBITS linking warning
    Joel Sherrill
    joel.sherrill at OARcorp.com
    Mon Oct 12 11:19:28 UTC 2009
Ralf Corsepius wrote:
> On 10/11/2009 07:52 PM, Joel Sherrill wrote:
>> Hi,
>> The powerpc/haleakala has this warning when it links
>> executables:
>> /opt/rtems-4.10/lib/gcc/powerpc-rtems4.10/4.4.1/../../../../powerpc-rtems4.10/bin/ld:
>> warning: section `.sbss' type changed to PROGBITS
>> I don't see this in other BSPs and can't spot the
>> magic difference.
> But I do - the halekala's linkcmds is quite different from most other
> BSPs ;)
I saw that but couldn't spot the important difference.
The ss555 has this warning also.  I am testing the fix
there and will commit it if it works here.
Thanks.
>> I would like to eliminate this one. Help is appreciated.
> This patch below seems to be doing the job.
> Index: haleakala/startup/linkcmds
> RCS file:
> /usr1/CVS/rtems/c/src/lib/libbsp/powerpc/haleakala/startup/linkcmds,v
> retrieving revision 1.3
> diff -u -r1.3 linkcmds
> --- haleakala/startup/linkcmds	16 Sep 2008 21:26:41 -0000	1.3
> +++ haleakala/startup/linkcmds	12 Oct 2009 03:48:03 -0000
> @@ -210,8 +210,7 @@
>         . = ALIGN (4);
>   	  PROVIDE(__SBSS_START__ = .);
>   	  sbss.start = .;
> -      *(.sbss*)
> -      *(.gnu.linkonce.sb.*);
> +      *(.sbss .sbss.* *.gnu.linkonce.sb.*);
>   	  sbss.end = .;
>       } > RAM
>       PROVIDE(__SBSS_END__ = .);
> Ralf
