Adding new board support option
    Ralf Corsepius
    ralf.corsepius at rtems.org
    Wed Oct 21 06:43:59 UTC 2009
On 10/20/2009 03:27 PM, Joel Sherrill wrote:
> Peter Dufault wrote:
>> On Oct 20, 2009, at 5:30 , Ralf Corsepius wrote:
>>> However, you should really check, if you actually want an exported/
>>> global define in bspopts.h or an AM_CONDITIONAL.
>> You are correct, I don't want either of them. I am now unconditionally
>> adding the new network driver and I assume it will be resolved at link
>> time by the BSP user.
> You do need to make sure configure.ac and Makefile.am
> turn it off if networking is disabled.
Not necessarily. Instead, you can conditionally compile the code (I.e.
apply compile-time conditionals/defines instead of automake-conditionals).
Working principle:
#include <rtems/cpuopts.h>
#ifdef RTEMS_NETWORKING
<networked code>
#endif
This works as long as there are no files which need to be installed
conditionally. If the later is the case, AM_CONDITIONALS are inevitable.
Ralf
