problems building rtems from source
Thu Oct 29 03:46:59 UTC 2009
Yaad Gal wrote:
> I am trying to build rtems kernel from his source and I recieve an error
> when trying to compile
> I am using mingw on winXP.
Which tool version are you using ?
Where is the configure phase ?
I would not configure and build the source tree and I would not create a file
called makefile. The configure phase will overwrite it.
Have you read this section of the user manual ?
http://www.rtems.org/onlinedocs/doc-current/share/rtems/html/started/started00024.html
Regards
