GCC SPARC FPU issue status
Manuel Coutinho
manuel.coutinho at edisoft.pt
Tue Sep 1 08:50:53 UTC 2009
Hi
Was checking some mails exchanged in this mailing list a while ago (2006)
(http://www.rtems.com/ml/rtems-users/2006/may/msg00040.html) and would like
to know if the issue concerning GCC and SPARC floating point registers is
now solved or not. Does anybody know the status of this issue? Is there a
bug in GCC bugzilla so that we can track this? try to find but with no luck
Briefly, the problem, as far as I understood, occurs when a function
receives multiple arguments: GCC might store some arguments on FPU
registers, which could cause all sort of problems, like an invalid FPU trap,
or an erroneous result on a thread that uses FPU (because the register was
changed).
This problem could be solved by compiling RTEMS with -msoft-float flag and
the application without this flag (for the sections that want to use
floating point).
It also seams that ERC32 has a different behavior than Leon2 and Leon3: for
Leon2 and Leon3, RTEMS does not save/restore hardware FPU during a context
switch. Is this correct? Shouldn't the 3 BSPs have the same behavior?
Shouldn't leon2 and leon3 save/restore the FPU hardware during a context
switch?
(I'm looking at RTEMS 4.8.0)
Thanks in advance
Kind regards
Manuel Coutinho
URL: <http://lists.rtems.org/pipermail/users/attachments/20090901/8f1930ea/attachment.html>
